BX23 Won't Start
   / BX23 Won't Start #1
dboz
Danville,Ia
Kunitz bs 23
Bs 23 will not start. Have power and it will start if you jump the starter. Think it is the lever switch. How do I check that for sure?
   / BX23 Won't Start #2
This is for a BX25, I expect a 23 will be similar, but may not be the same.
From the wiring diagram there are the following things in the starter circuit.
Slow blow 50 amp fuse (or fusible link) in main cable from starter main terminal to fuse block and main switch, (OFF/ON/GLOW/START switch), PTO switch, HST Neutral switch, solenoid. Give the PTO and HST switches a workout!
   / BX23 Won't Start #3
Check to see there is no dirt/debris on the selector lever... it should be easy to move.
Hydro forward/reverse in the middle position too~
   / BX23 Won't Start #4
I agree with 100td. (the fuse). we had one and there was a fuse in the harness at the starter it would blow every 6 months. check that fuse with test light for power
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A60432)
UNUSED RAYTREE...
