bx23 pictures
/ bx23 pictures #1
MBman
Atlanta
here's a few bx23 pictures over the last two months.
/ bx23 pictures
more
/ bx23 pictures
again
/ bx23 pictures
twins
/ bx23 pictures #5
Nice Pics... /forums/images/graemlins/cool.gif
But I must say I got confused by your sig line and kept looking for the 4' brush cutter! /forums/images/graemlins/blush.gif
Probably because I am thinking of getting one for my BX, which seems more stable on slopes than my B2910 with the 5' brush hog on the back... /forums/images/graemlins/smile.gif
My error...but still, if you can post a pic of your bx from the rear with the brush hog on the back, I look forward to seeing it... /forums/images/graemlins/smile.gif
/ bx23 pictures
may not have the view your looking for right now
/ bx23 pictures
here's the bx mowing mud
/ bx23 pictures
anyother shot while waiting for a tow
/ bx23 pictures #9
Thanks for the quick reply... /forums/images/graemlins/smile.gif
Looks pretty good to me. I also need to get some bar tires, which I think I will get foam filled for safety reasons on my slope...
Do you find that the BX turns the rotary cutter pretty well? I suppose it should...all things considered, for the size it seems to have more PTO hp per lb than my B2910...
/ bx23 pictures
I knock it or bend it over with the fel and run it down' it has tons of power' don'tthey use this engine for larger tractors too?
/ bx23 pictures
I have my rear tires liquid filled. I'd highly recommend it. Here's my thoughts on tires. I've had three flats from brush cutting. Maxxis is releasing a kevlar belted power lug m7515 ag tire. I couldn't get my hands on them yet - but it's what i will put on next if I have another problem. In the meantime I have found tire liners for the front tires and have had both installed. As a side benefit I believe the addition of the liner and tubes to the front have added about 10 lbs. a piece to them.
I was planning to purchase another set of wheels and turf tires. I changed my mind. My neighbor has a set and loves them. I don't know why. He gets stuck on wet grass then stuck in level mud without sinking first just sitting there at least I buried it (in those pictures where I got stuck. I was in 4wd. at wot. high range and full hst forward speed with the brush cutter up - I was going to see if it was going to be too soft - and it was).
Anyway my bar tires haven't torn up my lawn at all even in 4wd on very steep grades. So my next thought was to buy a set of bars as spares since I had 3 flats in two months. But if I could buy those new maxxis power lugs with the kevlar puncture resistant belting (no more flats) that's what I'd do and use them for evrything.
Rich
2002 Hyster C330B Articulated Tandem Drum Vibratory Roller (A61572)
2002 Hyster C330B...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2017 Nissan Juke SUV (A61574)
2017 Nissan Juke...
2015 Ford F-350 Auto Crane Econo Ton II/R 1 Ton Service Truck (A61573)
2015 Ford F-350...
2002 Freightliner Allegro Bus Class A Motorhome (A61574)
2002 Freightliner...
2010 GMC W5500 HD 16FT Box Truck (A61573)
2010 GMC W5500 HD...
