BX23 Fuel Issue Help...
/ BX23 Fuel Issue Help... #1
tshep
Richmond, VA
BX23 MLB
Ok, was running just fine.
Tank got low.
Engine burbled once, I cut it off and went for fuel.
Got Kroger car fuel, no fuel buddy!
On restart (no burble), after a while (10 minutes?), lost high RPM power, hi rpm burbles, etc... got through the day.
Threw in Diesel 911 per NAPA recommendation, no better. Through the day affected lower RPMs. Got through the day, coming home tomorrow.
I have 1 Kubota fuel filter in hand - do I change first (pre lift pump) or second (pre pressure pump on engine).
First or second if only 1 in hand?
/ BX23 Fuel Issue Help... #3
Also, when the tractor is KOEO, is there noise like a pump emminating from the bottom of the tractor where the lift pump is?
I do hear the pump, it was changed, oh, 150 hours ago.
/ BX23 Fuel Issue Help... #5
On principle, try bleeding the fuel system per the manual. It may not help but can't hurt.
Well, first filter seemed to do it, Messicks on the way, and no work days for 10 days or so... so probably solved!
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
KMC 3pt 5' Rotary Tiller (A64119)
KMC 3pt 5' Rotary...
KMC 3pt 6 Row Vine Lifter (A64119)
KMC 3pt 6 Row Vine...
2022 Mercury Verdado 300HP Outboard Boat Motor (A61574)
2022 Mercury...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
