BX23 Fuel Issue Help...
/ BX23 Fuel Issue Help... #1
tshep
Richmond, VA
BX23 MLB
Ok, was running just fine.
Tank got low.
Engine burbled once, I cut it off and went for fuel.
Got Kroger car fuel, no fuel buddy!
On restart (no burble), after a while (10 minutes?), lost high RPM power, hi rpm burbles, etc... got through the day.
Threw in Diesel 911 per NAPA recommendation, no better. Through the day affected lower RPMs. Got through the day, coming home tomorrow.
I have 1 Kubota fuel filter in hand - do I change first (pre lift pump) or second (pre pressure pump on engine).
First or second if only 1 in hand?
/ BX23 Fuel Issue Help... #3
Also, when the tractor is KOEO, is there noise like a pump emminating from the bottom of the tractor where the lift pump is?
I do hear the pump, it was changed, oh, 150 hours ago.
/ BX23 Fuel Issue Help... #5
On principle, try bleeding the fuel system per the manual. It may not help but can't hurt.
Well, first filter seemed to do it, Messicks on the way, and no work days for 10 days or so... so probably solved!
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
