BX23 Fuel Issue Help...
/ BX23 Fuel Issue Help... #1
tshep
Gold Member
Richmond, VA
BX23 MLB
Ok, was running just fine.
Tank got low.
Engine burbled once, I cut it off and went for fuel.
Got Kroger car fuel, no fuel buddy!
On restart (no burble), after a while (10 minutes?), lost high RPM power, hi rpm burbles, etc... got through the day.
Threw in Diesel 911 per NAPA recommendation, no better. Through the day affected lower RPMs. Got through the day, coming home tomorrow.
I have 1 Kubota fuel filter in hand - do I change first (pre lift pump) or second (pre pressure pump on engine).
First or second if only 1 in hand?
/ BX23 Fuel Issue Help... #3
Also, when the tractor is KOEO, is there noise like a pump emminating from the bottom of the tractor where the lift pump is?
I do hear the pump, it was changed, oh, 150 hours ago.
/ BX23 Fuel Issue Help... #5
On principle, try bleeding the fuel system per the manual. It may not help but can't hurt.
Well, first filter seemed to do it, Messicks on the way, and no work days for 10 days or so... so probably solved!
2011 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A60736)
2011 ORTEQ ENERGY...
2017 Ford F-550 Ext. Cab Enclosed Service Truck (A61568)
2017 Ford F-550...
2021 WACKER NEUSON LIGHT TOWER (A60736)
2021 WACKER NEUSON...
TANK MANIFOLD (A58214)
2011 Ford F-250 Knapheide Service Truck (A61568)
2011 Ford F-250...
2016 Dodge Grand Caravan van (A61569)
2016 Dodge Grand...
