Loader BX23 bucket pin removal.
   / BX23 bucket pin removal. #11
Isn't line boring important so the bucket holes are aligned perfectly? Is welding new supports on without boring a good idea?
   / BX23 bucket pin removal. #12
It's not a good plan but sometimes you have to make due with what you can afford to do. Mine has been working for 8+ years but you do get what you pay for...
Here's what I have. As I said, it only has a single hydraulic cylinder, and it seems fine. The pins are loose in the arms, and seem seized in the bucket. I have a couple of ideas.
   / BX23 bucket pin removal. #14
Well....with that much wear I doubt they are frozen into the bucket.
It looks like the pins are froze into the loader arm and you have been rotating in the bucket.
   / BX23 bucket pin removal. #15
Agree 100% - the bucket holes are worn. I would convert it to a QA bucket set up or look for a new/used bucket in FB or CL - I have seen them for 3-400$
There are sleeves/bushings in the loader arms and if you can get the grease zerk to take some grease or get penetrating oil in there they may loosen up too.
   / BX23 bucket pin removal. #17
Embarrassingly, I never greased the pins on the bucket. The grease zirk is on the bottom, and it lubes the pin from the center. I never noticed it. The the bucket has some "slop" in it, so I bought a pair of pins, (PN 75532-58740), from a local dealer. I've removed the grease fittings and been spraying some kroil around the pins in an attempt to loosen things up, but they seem pretty stuck. I wondered if anyone had removed theirs?
Interestingly enough, I just finished removing a seized bucket pivot pin from the end of my model 7 John Deere backhoe dipper stick last night. Embarrassingly, the pin had been stuck since before I bought it over 10 years ago.
I cut one end of the pin off with a sawzall so I could get the bucket out of the way. Then I heated each end to 500-ish degrees. I tried turning it with a 18" pipe wrench and a binder cheater bar. I heard it make a sharp creaking sound a couple of times, but ended up wrecking the teeth on the pipe wrench and really chewed up the end of the pin.
I welded a piece of 3/8" angle metal with a 1" hole cut in it to the uncut end and used the same wrench set up to get it to turn about 180 degrees. This set up ended up twisting part of the end of the pin off. It was a little weak because of the 1/4" retainer pin hole in it.
Next I pulled the dipper from the boom and drilled a 3/8" hole through the pin. After grinding a slight taper to the ends of the pin, I used a double jack sledge hammer to drive it back and forth a couple of times. Then finally drove the pin flush on one side.
I used a piece of 1" all thread to drive it through, starting with a single jack until the all thread was far enough into the bushing that it would stand on its own. Then finished beating it through with the double jack. I must say, it has been a loooong time since I have beat on something as hard as that (retired carpenter).
Now I have to remember where I found the supplier to provide material that I can make a new one. I wish I had ordered it when I found it. They are no longer available from John Deere, and if they were, I would not buy from them because they were priced as high as gold bar.
   / BX23 bucket pin removal. #18
John Deere gives capitalism a bad name.
   / BX23 bucket pin removal. #19
I don't have one of these FEL's nor a photo, so don't know whether any of these methods could be used:
1. Years ago, used a hand held air hammer which has bits held in by a big spring and hook on end, with a a stubby bit having a round slightly < the diameter of an engine piston wrist pins, held a piston / connecting rod assembly by the connecting rod in a bench vice, to hammer out the interference fitting wrist pins. Method was used frequently by a co-mechanic who drag raced GTO's. On my 2 small block Corvettes, held up good for 6,000 rpm runs. This method has the advantage of not burning off your FEL paint, nor heat treating (or undoing).
2. Extremely heat up, trying to direct to just one of the two items stuck together. After cools, the cycle may break or weaken the bond. Methods of heating:
A. Torch
B. MIG deep weld a spot on the end, for example in the center of the head of a bolt, retains circumference for box wrench access. If your FEL pin has a handle, may be able to weld on that near the stuck joint. Other types of welders may work also.
C. I've seen descriptions of induction heaters for rusted bolts. If too pricey to buy for 1 job plus the learning time, maybe a shop has one they would attempt for you. Has value in their experience and misc other tools. Or, maybe a tool rental business rents.
Wish you success!
   / BX23 bucket pin removal. #20
Other ideas:
1. If you have a lot of time before has to be loose, can apply penetrating oil on it repetitively. Try to move it each time. Tap with a hammer? When I was a high schooler, my father bought a 4 cylinder car with spark plug holes straight up. Engine was frozen from barn storage. He put penetrating oil in the holes frequenty. Left it in gear. Told us boys to push n pull on the bumper every time we walked past. I thought he was nuts. After several months, it broke loose. Became drivable without disassembly.
2. Knew a guy that had a boat propeller stuck on a thru hull taperred prop shaft. He hit the hub multiple times with a hammer. Popped apart. May have had a person on the back side holding another hammer against it. I've used this. Is a hit causing an automatic rebound hit. You may have to use a chisel to locate the shock. May help if can hit multiple areas retaining the pin.
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
23169 (A50324)
23169 (A50324)
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
