BX2200
/ BX2200 #1
Anonymous Poster
Epic Contributor
I have a BX2200 that runs for about 5 minutes and then dies, let it sit for awhile and then it restarts. I already changed the two fuel filters, any other ideas? Also I find the hydro pedal to stay down and very slow to return to neutral, anybody seen this with the BX2200 and what is the cure? Thanks
Doctor
/ BX2200 #2
There are several post on the HST sticking and the fix. Just search this site. Kubota is now installing a grease fitting on the HST control. You might check with your dealer about this. I disconnected the shock cylinder inside the frame on my BX2200 and adjusted the spring tension. I haven't had any problems since then. On the stalling, my BX did the same thing. It turned out that the dealer had gotten water in the fuel system. They changed the filters, drained the tank ect. and I haven't had any problems since. Hope these ideas help you. I have about 47 hours on my tractor and it's running great. It is a fun tractor to drive.
/ BX2200 #3
Call the dealer, and they should be able to remedy both issues. As Watersjj noted, the sticking HST fix is known, and correctable by Kubota. Rather than fight these problems, put the warranty to use. Hopefully, you'll be back in the seat in no time!
Roy
/ BX2200 #4
hey brian,
try running with the fuel cap lose. maybe it isnt breathing correctly. what do they call it, vapor lock?? i dont know anyway im just guessing at something i would try.
rich
/ BX2200 #5
Thanks guys, I will check all these out and if I fail I will call the dealer. This site is awesome
Doctor
/ BX2200 #6
I would have already called the dealer and had him out there! Probably you have water in the fuel. Heck, these new tractors--get the dealer out there. J
/ BX2200 #8
Yes ddl, the muffler belt is a good guess, could be right but I would check that kanuder valve operation before the belt thingy. Sometimes they stick closed and cause all kinds of consternations to occur. Of course if the muffler belt is contorting it could cause cyclic feed back into the fuel mesmeriser at which point one would be totaly sc----d! J, flamdangled
/ BX2200 #9
hey,
is the muffler belt an option. i dont have one i dont think?
im gonna call the dealer today and ask. it probably holds it on tighter and reduces any exhaust leaks, right?
rich
/ BX2200 #10
geez guys I come on here for a little support and I get the run around, muffler belt and the kanuder valve, I dont know who to believe. I took it to my dealer maybe they can repair it.
Doctor
2019 John Deere 350G Hydraulic Excavator (A59228)
2019 John Deere...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
iDrive TDS-2010H...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
John Deere 6195R (A60462)
John Deere 6195R...
