BX2200 -- will almost start
/ BX2200 -- will almost start
I think there are 2 coils in the fuel stop solenoid. One is energized while starting, and the other is energized while running). Could be the run coil is fubar.
The tractor should start and run with the solenoid removed.
I can pop that off(pretty easy overall) wasn't what I saw in the past. Usually it wouldn't even start to turn over. But, that will have to be tomorrow :)
/ BX2200 -- will almost start #22
Never had a fuel stop solenoid keep it from cranking over. Had it cough and not run but only thing that stopped the started was Starter Solenoid, starter or lack of power.
BTW my BX2200 has 4500 hours and the glow plugs are working fine, damn I bet they die now..... :mad:
I did reach out to the Kubota Dealer and they seem to be leaning toward the ignition switch or a wiring issue as well. Also suggested the timer but doubted that and i hate throwing parts at something.
I'll probably trace wiring later today.
/ BX2200 -- will almost start #24
I'm betting on fuel issue and as Eagle1 has noted I'd be looking at that fuel solenoid.
Good luck.
/ BX2200 -- will almost start #25
If the stop solenoid is removed and the starter spins over good, there is nothing electrical keeping it from running except the lift pump under the tractor providing fuel to the injector pump.
These things are simple, mechanical injection, no ignition, no ECM, nothing. If you have fuel to injector pump and compression it needs nothing else. If your stop solenoid sticks engaged (or you remove it) you can't shut the thing off electrically.....removing air or fuel is the only way to stop that little motor, well you can stall it with enough load.
/ BX2200 -- will almost start #26
Just a thought did you change BOTH fuel filters? The one under the tractor near the lift pump is normally the one that fills up with gunk
/ BX2200 -- will almost start #27
Just to throw this out there... Have you checked the air filter?
Fuel / Air / Compression are required.
The clicking sound in the video is the electric lift pump, and it sounds normal.
I did check the air filter and I didn't do botth fuel filters I did the one and made sure it was pumping fuel pretty well.
Is the "fuel solonoid" near the start stop one?
/ BX2200 -- will almost start #29
$25 on Amazon or Ebay.
A followup...
1) I took out the glow plugs(they all tested at 1.3 ohms) == they are good.
2) I then connected them to the bar and twisted the key so that the glow plug light was on.
They did not get warm at all.. so it may be a wiring issue. I could have sworn that I tested that connection earlier but it may have gotten fragile(like that leg lamp in the window at christmas).
Next step is to check that.
/ BX2200 -- will almost start #32
I could be wrong, but I don't think faulty glow plugs would prevent it from starting, unless it's really cold.
Have you checked each injector line, at the injector, while cranking? You should have spurts of fuel when it cranks.
I'm interested to see what you figure out.
/ BX2200 -- will almost start #33
There should be a key position just prior to cranking where the glow plugs are automatically energized. A light on the panel indicates power is applied to the glow plugs. In cool weather hold it there for a few seconds to build some heat before you start cranking. It should start quickly.
A followup...
It sounds like the ignition switch is doing its job, but somewhere between the indicator light and the glo plug buss there is a fault.
I'll be working over the next few days.. if I can figure it out I will respond with what it is.. otherwise to the dealer it goes :-(
/ BX2200 -- will almost start #35
Did you try starting fluid, to verify that it want's to run?
/ BX2200 -- will almost start #39
NOOOOO! No ether on any Kubota!
True but now I'm wonder if it was filled with gas. Could be very hard to start with gas instead of diesel.
I will say ether help me troubleshoot the stop solenoid full of water.... :rolleyes:
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
Harlo HP6500 (A60462)
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
2003 Big Tex 10PI...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
