BX2200 Starting Problem
/ BX2200 Starting Problem #1
pemad
Syracuse, New York
B7510 HST
I figured I would pass this on to others that may come across the same problem.
I went to start my BX the other day and did the normal procedure of putting the tractor in neutral and turning the key but nothing happened. The tractor did not turn over but just made the normal clicking noise. I assumed the battery needed a charge, but after hooking up the batter charger the battery had A reading of full. I then looked around the tractor and found the neutral switch (not sure what it is called) which needs to be depressed in order for the tractor to start. It was not, so I took off the rear tire to access the switch and found that the 2 bolts that hold the switch in place came lose. I readjusted the switch and I was off and running.
/ BX2200 Starting Problem #2
pemad,Thanks for the tip,I will keep that in mind.
John Deere 6300 (A60462)
John Deere 6300...
3PT WEIGHT DRUM W/ CONCRETE FILLER (A63291)
3PT WEIGHT DRUM W/...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
