bx2200 deck issue
/ bx2200 deck issue #1
warment
Cub Cadet RZT54
Has anyone else had the left side of the mmm come loose from the spring loaded pin? Mine did 2 times today...simple fix...pull the pin outwards, lift the deck by hand...reinsert pin into deck bracket...
/ bx2200 deck issue
It is like the pin needs to be longer, or thr pin needs to have a hole in the innermost part so a cotter pin could be inserted...
/ bx2200 deck issue
I figured this out...the left arm should be shaped like a "C" where the pin goes through it as on the right arm. On mine, part of the "C" is broken off. I will probably just buy a new arm ($83 on coleman equipment).
/ bx2200 deck issue #4
I had a similar problem on the 60" mmm deck for my B2150. Turns out the weld was broken where the L-shaped part of the clevis or "C" was fastened to the long arm. I had it welded back on and all is well now. Your spring-loaded pin should go well beyond the hole in the other side of the clevis and should never present a problem staying in place. I think you can get the "C" part welded and repaired for a lot less than $83 but the difference may include the price for peace of mind. I suggest studying the daylights out of your support brackets and entire mower deck and mechanisms -- making sure there is nothing else wrong. I assume you do not know how this break happened ? Another comment, which may just be our English, but you said BROKEN? Those parts are all mild steel and would bend, not break so far as I know (other than breaking a weld as mine did.)
/ bx2200 deck issue
It is definitely broken. I reached around back and felt a sharp edge. Not sure how it happened as I bought it used from my neighbor only a few months ago. I ordered a new one yesterday. Thanks for the input.
/ bx2200 deck issue
I will try to remember to post a pic of the old one when I remove it.
/ bx2200 deck issue #7
This is mine when I had it clamped ready to weld the L-shaped piece back on the bar for holding up the deck.
/ bx2200 deck issue
Could not get to the pic. I would have welded mine too if I had the broken piece to weld back on.
/ bx2200 deck issue #9
This should open up for you by clicking on it. If not, no idea what that problem is.
/ bx2200 deck issue
It worked that time. Thanks.
/ bx2200 deck issue
I removed the left arm yesterday. I should receive the new one today and be able to install this evening.
/ bx2200 deck issue
/ bx2200 deck issue
/ bx2200 deck issue
Old and new left side deck arm. You can clearly see the missing/broken piece.
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
UNUSED RAYTREE RMBD72ST-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2022 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2022 CATERPILLAR...
