bx2200 deck issue
   / bx2200 deck issue #1
warment
Cub Cadet RZT54
Has anyone else had the left side of the mmm come loose from the spring loaded pin? Mine did 2 times today...simple fix...pull the pin outwards, lift the deck by hand...reinsert pin into deck bracket...
   / bx2200 deck issue
It is like the pin needs to be longer, or thr pin needs to have a hole in the innermost part so a cotter pin could be inserted...
   / bx2200 deck issue
I figured this out...the left arm should be shaped like a "C" where the pin goes through it as on the right arm. On mine, part of the "C" is broken off. I will probably just buy a new arm ($83 on coleman equipment).
   / bx2200 deck issue #4
I had a similar problem on the 60" mmm deck for my B2150. Turns out the weld was broken where the L-shaped part of the clevis or "C" was fastened to the long arm. I had it welded back on and all is well now. Your spring-loaded pin should go well beyond the hole in the other side of the clevis and should never present a problem staying in place. I think you can get the "C" part welded and repaired for a lot less than $83 but the difference may include the price for peace of mind. I suggest studying the daylights out of your support brackets and entire mower deck and mechanisms -- making sure there is nothing else wrong. I assume you do not know how this break happened ? Another comment, which may just be our English, but you said BROKEN? Those parts are all mild steel and would bend, not break so far as I know (other than breaking a weld as mine did.)
   / bx2200 deck issue
It is definitely broken. I reached around back and felt a sharp edge. Not sure how it happened as I bought it used from my neighbor only a few months ago. I ordered a new one yesterday. Thanks for the input.
   / bx2200 deck issue
I will try to remember to post a pic of the old one when I remove it.
   / bx2200 deck issue #7
This is mine when I had it clamped ready to weld the L-shaped piece back on the bar for holding up the deck.
   / bx2200 deck issue
Could not get to the pic. I would have welded mine too if I had the broken piece to weld back on.
   / bx2200 deck issue #9
This should open up for you by clicking on it. If not, no idea what that problem is.
   / bx2200 deck issue
It worked that time. Thanks.
   / bx2200 deck issue
I removed the left arm yesterday. I should receive the new one today and be able to install this evening.
   / bx2200 deck issue
   / bx2200 deck issue
   / bx2200 deck issue
Old and new left side deck arm. You can clearly see the missing/broken piece.
Kubota ZG222 (A60462)
Bobcat T590 (A53317)
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
2008 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2008 CATERPILLAR...
