BX2200 Bouncing
/ BX2200 Bouncing #1
okie350
Mounds Oklahoma
L3010 & BX2200
When going from reverse to forward direction i have noticed my little Bota seems to "bounce" two or three times before levealing out and roaring off. It only seems to do it if I only PARTIALLY push the peddle (like half way push it down) If I push all the way it does not seem to do it. Is this normal, or do I have the beginnigs of problems?
/ BX2200 Bouncing #2
Perhaps "I have no idea what you're talking about" isn't the most helpful answer. Or perhaps that confirms your suspicions.
/ BX2200 Bouncing #3
I'd be wondering about your foot on a partial movement causing that type movement.
/ BX2200 Bouncing
Ok, Hydrostatic transmission, while mowing around objects i frequently have to back up, and then move forward. I seem to get a bouncing in the transmission when I back up and then move forward, especially when i only mash the go peddle partially. If I push it all the way to the floor it takes off like normal (snaps your neck back speed)
Does this explination make more sense now?
/ BX2200 Bouncing
I have noticed that my foot will agravate the problem. Once I start bouncing my foot will start bouncing on the peddle and make it worse
/ BX2200 Bouncing #6
You will need a good counter weight on your 3pt to balance your load, this will avoid many problems...
/ BX2200 Bouncing
Im mowing, why would I need a counter weight? there is no loader on this machine, just used as a mower
/ BX2200 Bouncing #8
make sure your tire pressure is correct. Soft tires will contribute to the
bounce. Weight on the 3pt will also help to damp out the bounce.
Bill
/ BX2200 Bouncing #9
Just a shot in the dark, but if the BX2200 has the gas spring shock dampening the fwd/rev pedals like the BX2350, it could be bad
/ BX2200 Bouncing
Bill
I must be describing this incorrectly.It is NOT bouncing like going over bumps or carring a load but "surging" "maybe this is a better description"
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
Four (4) Michelin 520/70R38 Mega Bib Floater Tires (A63116)
Four (4) Michelin...
1996 Sunflower 1543-38 Folding Disk (A63118)
1996 Sunflower...
2006 KENWORTH T600(INOPERABLE) (A63569)
2006 KENWORTH...
Kuhn Axis 50.2 H-EMC-W Fertilizer Spreader (A64047)
Kuhn Axis 50.2...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
