Grading BX2200 3pt grader blade
   / BX2200 3pt grader blade #11
Rocketman... Are you using that KK blade on a BX2200? If so, is your blade one of the XB series blades or a standard KK blade?
I took back the one that would not work with out some modification. Picked up a Woods RBC60 Estate series and it works perfect. Thanks for the suggestion. The thing I learned in all of teh shopping around is that the bx2200 3pt is not compatible with every thing but is "limited". That is ok as ling as you keep that in mind when looking at implements.
   / BX2200 3pt grader blade #13
Yep, I'm using it on a BX2200. /forums/images/graemlins/confused.gif I don't think I know the difference between an XB and a regular KK. The data label is scratched up pretty good; however, I think it reads TRB-60T. There is a total of 10 adjustments (five forward and five reverse). Hope this helps.
   / BX2200 3pt grader blade #14
Thanks Rocketman
KK came out with a line of implements that are designed for sub compact tractors (XB line). I wondered if yours was one of the new designs. I bought an XB middle buster/subsoiler this spring. It is the right size for my BX but the quality was pretty bad (more cosmetic than structural).
John
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
30' E-Z Trail Head Cart (A59814)
30' E-Z Trail Head...
2018 Kubota U17 (A53317)
2018 Kubota U17...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
