Grading BX2200 3pt grader blade
   / BX2200 3pt grader blade #11
Rocketman... Are you using that KK blade on a BX2200? If so, is your blade one of the XB series blades or a standard KK blade?
I took back the one that would not work with out some modification. Picked up a Woods RBC60 Estate series and it works perfect. Thanks for the suggestion. The thing I learned in all of teh shopping around is that the bx2200 3pt is not compatible with every thing but is "limited". That is ok as ling as you keep that in mind when looking at implements.
   / BX2200 3pt grader blade #13
Yep, I'm using it on a BX2200. /forums/images/graemlins/confused.gif I don't think I know the difference between an XB and a regular KK. The data label is scratched up pretty good; however, I think it reads TRB-60T. There is a total of 10 adjustments (five forward and five reverse). Hope this helps.
   / BX2200 3pt grader blade #14
Thanks Rocketman
KK came out with a line of implements that are designed for sub compact tractors (XB line). I wondered if yours was one of the new designs. I bought an XB middle buster/subsoiler this spring. It is the right size for my BX but the quality was pretty bad (more cosmetic than structural).
John
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
2012 International Derrick Digger (A55973)
2012 International...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
Great Dane Van Trailer (A56435)
Great Dane Van...
