BX22 Glow Plug Removal & Compression Test
/ BX22 Glow Plug Removal & Compression Test #1
DOC4444
Massachusetts
Kubota BX22
I went to adjust the valves to address a misfire problem and attempted to remove the glow plugs, as I had been advised, to make it easier to turn the flywheel.
I had no problem unscrewing one glow plug, but it would not come out of the hole with amount of force I was willing to apply. So, I had to turn the flywheel with them in place. It was really quite easy, with little variation, which concerned me.
Is it normal on a 1000 hour tractor for the glow plugs to take a LOT of force to remove?
Should it be, as I would expect, difficult to turn the flywheel with the glow plugs in place?
Thanks!
DOC
/ BX22 Glow Plug Removal & Compression Test #2
I am a diesel mechanic and turn engines over manually everyday with glow plugs and injectors still installed. I suspect after a 1000 hours of use, they are probably swollen.
Sent from my iPhone using TractorByNet
So, just pull harder on the glow plugs, or??? Also, does the lack of "variable" effort indicate a potential compression problem?
Thanks!
DOC
/ BX22 Glow Plug Removal & Compression Test #4
Pull harder or depending on the type/style, you can buy a glow plug extractor.
I see a dizzying array of glow plug extractor tools/kits to purchase. What is the correct one for 2003 BX22 Glow Plugs?
Thanks!
DOC
/ BX22 Glow Plug Removal & Compression Test #6
I would have to see a visual picture of the glow plug installed to recommend a puller.
2014 Chevrolet Express Shuttle Bus (A64556)
2014 Chevrolet...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2006 Ford Freestyle (A64557)
2006 Ford...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
2021 POLARIS RANGER XP1000 RTV (A65054)
2021 POLARIS...
2025 Grapple Rake Mini Excavator Attachment (A64553)
2025 Grapple Rake...
