BX22 3pt hitch?
/ BX22 3pt hitch? #1
Anonymous Poster
Epic Contributor
I finally took off the FEL and BH (boy did that help out the mowing duties!!!) and connected the 3pt hitch. I drove across the field to another barn to hook up a 48" Howse bush hog and realized one thing. It looks too darn narrow to hook up. The ends of the 3pt hitch are too narrow to fit onto the bush hog!?!? Anyone else have this problem? I'm thinking of putting the bushhog pins facing inward so I can mount it? Do you see anything wrong with that? HELP :)
/ BX22 3pt hitch? #2
Turning the pins in is fairly common on implements used on the BX. If you search the threads, you will find quite a bit of discussion on these topic. There is nothing to worry about with most (if not all) implements.
/ BX22 3pt hitch? #3
Thanks! Sorry I wasn't logged in at the time of that post. I'll be sure to try the search feature next time (oops!) :) Thanks again. Chris
/ BX22 3pt hitch? #4
Is there any power problems or weight problems with this set up?
KCook
/ BX22 3pt hitch? #5
My experience with this is limited to using my landscape rake. I did not see any difference between this hook up and using a larger tractor with pins facing out. I know TresCrow and others have had much more experience.
/ BX22 3pt hitch? #6
The ends being "too narrow" - do you mean how far apart the hitch arms will spread? Have you loosened the check chains? Once the lock nuts on the check chains are backed off, the BX arms will spread wide enough for standard 26" cat I implements. If I've misunderstood the question, my apologies.
Frank
Chemical Containers Tank (A57148)
Chemical...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2005 CHEVROLET 3500 HD CREW CAB FLATBED TRUCK (A60430)
2005 CHEVROLET...
UNUSED FUTURE MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED FUTURE MINI...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
