BX1850 tractor cab
/ BX1850 tractor cab #1
JHill
Bow, nh
BX1850
I just recently finished building a cab for my bx to be used for snow blowing. It is easily removed with 10 bolts. It is a 3 sides cab, but I could close it all in totally if I choose to. I am looking more for protection from the snow blowing back on me than for being able to heat it, although I may need to.
I tried to keep costs down, so I used some things I had around, but I had to buy most of it. It is constructed of 3/4'' plywood and plexi glass, with the glass held in with some gasket material I found on the internet. The gasket was probably the most expensive component, and the hardest part of the build, but it gave me the result I was looking for. I also used a piece of pvc coated commercial rubber roofing on the lid, custom mixed paint from the auto parts store, and I used some marine hinges on the door. I hinged the door on the sloped side so that it closes itself; it seems to work good that way, but I will find out this winter.
I'm wondering if I will have much of a fogging problem with it being 3-sided and having no heater. I store it in an unheated garage, and live in NH. I'd love to hear some thoughts on that. I don't know if any members have experience using the small 12 volt defroster units that can plug into a lighter type receptacle; not sure if they are effective.
Thanks for any and all comments
Jody
/ BX1850 tractor cab #2
Jody
With the one side being open and the cool/cold air allowed in I do not believe fogging will be an issue. Just to let you know you did a FANTASTIC job on building the cab. EXCELLENT!!!!!!
Thanks Stanley, I appreciate it.......I just moved the thread to the build it yourself section where it should have been in the first place!
/ BX1850 tractor cab #4
That is awsome! great job!
/ BX1850 tractor cab #5
Thanks for sharing! I want to build cab for my tractor, and the more ideas the better. Great job! Aaron
Thanks again for the comments.....I think it will work out pretty well.
Jody
/ BX1850 tractor cab #8
Hey, that looks good. I'm gonna say go ahead and close in the back and add a heater box. Once you've blown snow in your underwear........ you'll never go back to that snowmobile suit !! :thumbsup:
/ BX1850 tractor cab #9
very nice handi work. looks good to me. I agree it won't for with the rear open.
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2005 John Deere 7320 (A60462)
2005 John Deere...
Mini Skid Steer (A60352)
Mini Skid Steer...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
Caterpillar 740 Articulated Truck Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 740...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
