BX1500 purchase options - help needed
/ BX1500 purchase options - help needed #1
kwolfe
Platinum Member
Central PA
I am looking to purchase a BX1500 to replace my old one. My previous 1500 had a 54" deck and turf tires. My question for all you bx owners out there,
1) Is the 1500 better suited to drive the 48", or should I not notice the difference between 48" and 54",
2) does anyone pull a KK 3pt finish mower with there BX? Does is cut as well as the MMM?
3) the eternal question of bar or turf tires
I would say that at least 60% of my time will be mowing. The other 40% will be FEL, BB, snow plowing, maybe tilling one day. I don't think that they make R4s for this little machine or that would be my first choice probably.
/ BX1500 purchase options - help needed #2
kwolfe said:
1*I am looking to purchase a BX1500 to replace my old one. My previous 1500 had a 54" deck and turf tires. My question for all you bx owners out there,
2*Is the 1500 better suited to drive the 48", or should I not notice the difference between 48" and 54",
3* does anyone pull a KK 3pt finish mower with there BX? Does is cut as well as the MMM?
4*the eternal question of bar or turf tires
5*I don't think that they make R4s for this little machine or
1*Why are you having to replace a BX1500?
2*I'd go with the 54'' MMM if I was even going to go with a mower.
3*Why a pull mower over a MMM?
4*AG tires No question.
5*Ya mean worst choice don't ya !!!
Here is the way I would purchase a BX1500:
Front Blade
Rear Tiller
BAR Tires
No Mower at all.
I do about 80% of my mowing with the 60'' MMM on my BX23. The other 20% I mow with my new CC GT2554 with the 54'' mowing deck.If I wan't to get my place mowed in a hurry my wife and i mow together at the same time.
The 9.5 foot wide swath of the BX23 and CC 2554 combind makes short work out of mowing our 2.33 acres.
LBrown,
Why am I replacing: I found out that the 1500 I purchased used was originally stolen. After having spoken to the police, it turned out that I was probably the fourth or fifth guy to have it. Trust me, that is a phone call you never want to get.
The only reason I would consider pulling a 3pt moweris because it is cheaper. Also wonder if you get a better cut from it.
I would love to have a tiller, but that will have to wait to a later when I have money again (can't recoup what I originally paid,:mad: )
/ BX1500 purchase options - help needed #4
kwolfe -
A couple of years ago I bought a beautiful little B6100 - circa 1980. It was beyond mint - looked quite literally brand new - as it had been stored in a garage and barely used. I paid $4500 for it with snowblower and rear 48" Woods mower.
I got rid of the rear finish mower a week later, as it scalped the lawn something awful - I lived on a very slopy piece of property. The ridges of the hills got chopped down to soil - the concave lower sections of the slopes never got cut because it would ride up the slope before the blades could contact the grass - the anti-scalp wheels/bars cut into the ground on every turn.
If you live on a flat area - with, say a broad field to cut, then I think the rear finish mower is a viable option. If you have any terrain that has obstacles, slopes or imperfections, then the MMM is absolutely the way to go.
I sold the a few months later, as I could not find a FEL or a belly mower, which were the attachments that made sense for me. I have both on my new BX1500 and couldn't be happier! Sorry to hear of your financial loss - hope you have fun making your decisions, though, as this really ought to be a happy experience for you.
/ BX1500 purchase options - help needed #5
Kevin, I have the 54" deck, as well as bar tires sized for the BX1800 on my 1500. I would do both again. I would not reccommend R4s even if available. AGs give superior grab and sustained push in spin conditions on everything softer than hardpack, and on a little tractor are quite easy on turf unless they spin. That should be seldom to never in mowing. The engine is a little underpowered for the 54" deck but I like the way it sticks out further to the sides so you can get closer to overhanging bushes. It also decreases the effective turning radius of mowing. The slight underpower is only bothersome when you are mowing large areas and want to go faster.
Larry
I have heard that the bar tires are easier to puncher than the turf tire (due to the fact that the turfs have thicker rubber overall. Is this true?
/ BX1500 purchase options - help needed #7
I've never had that problem with the Lug tires on my BX23 in over 2 years and more than 775 hours.
My CC with a 54'' deck will run away with me mowing up a long steep hill.
Plenty of power there.
/ BX1500 purchase options - help needed #8
1*I like the way it sticks out further to the sides so you can get closer to overhanging bushes. It also decreases the effective turning radius of mowing. The slight underpower is only bothersome when you are mowing large areas and want to go faster.
Larry
1*Actually I can mower closer along ditches with my CC with the 54'' deck than I can with the BX23 with a 60'' MMM.
/ BX1500 purchase options - help needed #9
A little off the subject, but I must ask. Why have a subcompact tractor if you don't use it for mowing? Given the inherent limitations and small price difference I would have been more than happy getting a B7610 have much more "tractor" and less "mower".
Generally speaking, I think BX owners don't normally go into it planning on ALSO having a lawn tractor to maintain and replace. As for tight spots, that's why God invented the trusty push mower.
/ BX1500 purchase options - help needed #10
kwolfe said:
LBrown,
Why am I replacing:
1*I found out that the 1500 I purchased used was originally stolen.
2*The only reason I would consider pulling a 3pt mower is because it is cheaper.
3* Also wonder if you get a better cut from it.
4**I would love to have a tiller, but that will have to wait to a later when I have money again
5*(can't recoup what I originally paid,:mad: )
1*Oh that's so sad. What a bummer. I really feel for you.
2*You just might get a rider to mow with for even less.
3*I couldn't ask for a better cut than I get with the CC or the BX23.
4*One of the reasons I switched from wanting a BX1500 to going with the CC GL2554.
5*I don't blame you >I'd be :mad: too.
I was wanting a BX1500 like so.
Tractor 5700
Front blade 1300
Rear tiller 1500
Total 8500
Wasn't going to get any mower for it because I was mowing with a MTD power craft with a 46'' deck.
Before I could make a deal on it the power craft blew up so then I needed a mower.
New figures on the bx1500 then became
Tractor 5700
Front blade 1300
Rear tiller 1500
MMM 1500
Total 10000
10000 was a bit more than I wanted to put into another tractor so I changed my game plan and came up with the following.
New left over 2005 CC GT2554 with bar/lug tires.
Tractor 2600
Front blade 650
Rear tiller 800
54'' mower deck 1000
Total 5050 or half the cost of the BX1500.
__________________
I'm thinking about buying another CC and putting my 54'' deck on it so that I can leave the blade and tiller on the CC I already have.
Even after doing that I'd still have thousands less than 10000 in the whole works and have two tractors rather than just one in the deal.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Bobcat MT85 (A60462)
1993 M149A2 400 Gallon Potable S/A Water Tank Trailer (A59228)
1993 M149A2 400...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
2015 Cadillac ATS Sedan (A59231)
2015 Cadillac ATS...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
