Dirt Moving bx attachements?
/ bx attachements? #1
bxn
Ok, here are a bunch of different attachments on the link below for RTV's
Is there a point to looking at these for a bx series?
The demo looks interesting.
YouTube - ‪Quadivator demo clips‬‏
Should I be jealous of the RTV capability or are these under-performing attachments to make up for the vehicle there are targeted for?
Sort of shocked the RTV traction could be comparable.
TIA,
bxn
/ bx attachements? #2
I'm sure the BX could pull those around, but why not just get proper Cat 1 3PH implements. There are plenty fine ones out there.
/ bx attachements?
Danner,
The last one on the vid is two bottom plow - normally we are down to one.
The disk harrow (at 70in) is somewhat wider than recommended for the bx. So I'm wondering if the 3ph is actually more of a limitation for the implement size due to weight than what it can pull.
bxn.
/ bx attachements? #4
Interesting...But the soil looks to be pre-prepped...Might do a good job, who knows.
Besides, Anyone wear a crash helmet when you're doing this stuff?...Just sayin':D
/ bx attachements? #5
Danner,
bxn.
It looks lkike they are only plowing about 4" deep in that photo, and in good sandy loam soil. Given clay, and my rocks, etc., and plowing to a normal depth, I doubt the plows would work so well. I've pulled a 4' X 8' harrow of that type behind a BX, and the tractor didn't even know it was there... You have speed with an RTV, but I doubt ATV's weigh as much, or can do many of the things a tractor can. The implements shown look to be well made, but are made for a market. They help folks justify the cost of buying an ATV, or help them get more use out of the one they have. Like another member said, a BX would pull all those implements just fine.
/ bx attachements? #6
Why be jealous? It has the ball hitch, which the BX can easily use. The RTV 1100 is ~2500lbs and the BX24 is about the same with loader and MMM attached. The only difference I see is speed. The BX can easily pull the quadivator with no issues in the same conditions.
/ bx attachements? #7
No thanks, I have a Rhino and 700 Grizzly, but use a tractor for tractor stuff. If all you have is an ATV/RUV and need something to work on food plots, I can see it.
/ bx attachements?
Thanks for the replies. Seems like I should be looking at the standard stuff to do a good job.
bxn
2017 Subaru Forrester (A62613)
2017 Subaru...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
(5) 12' CARPETED BOAT GUIDES (A64280)
(5) 12' CARPETED...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
