Chains BX 25 tire chains
/ BX 25 tire chains #1
zleader
I am trying to install tire chains on a BX 25 but their is not enough room between the tire and the sub-frame, has anyone ran into this problem ?
/ BX 25 tire chains #2
Its pretty tight, but there is enough room for them to be run on. Currently I don't use them in the snow, only in mud.
/ BX 25 tire chains
have you had any experience with wheel spacers, my chains hit the frame ...
thanks
/ BX 25 tire chains #6
/ BX 25 tire chains #7
I have the 2 link ladder chains (with tensioners!) on this page;
tractor tire chains for farm tractors
on my BX 25 and have no clearance problems. There is not a lot of room to spare but they do fit. I did put extra springs on the tensioners as insurance, but there were no problems before. I'm using turf tires.
/ BX 25 tire chains #9
If you have any hills, definitely get the rear wheel spacers from bro-tek. It's like a whole other machine with them as far as lateral stability goes.
I have a BX25 with A4's (thanks Barlows!), 2 link V-bar tire chains (thanks tirechains.com!), and the rear spacers (thanks Rich@ bro-tek!) and skid plates.
The beast can climb trees with this setup.
I have tensioners on the front tires since there's less clearance with the steering up front, but on the rear wheels the chains are just cinched down pretty tight.
/ BX 25 tire chains
Thank you everyone for the help. I removed the tire and put the chain between the treads on the tire and tighten then down good. Its very close, but appears to work. Its strange that a tractor would have so little clearance for chains given the snow blower option is ready available. Its a great tractor though !!
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
2011 Mercedes-Benz C300 AWD Sedan (A66738)
2011 Mercedes-Benz...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
