Chains BX 25 tire chains
/ BX 25 tire chains #1
zleader
I am trying to install tire chains on a BX 25 but their is not enough room between the tire and the sub-frame, has anyone ran into this problem ?
/ BX 25 tire chains #2
Its pretty tight, but there is enough room for them to be run on. Currently I don't use them in the snow, only in mud.
/ BX 25 tire chains
have you had any experience with wheel spacers, my chains hit the frame ...
thanks
/ BX 25 tire chains #6
/ BX 25 tire chains #7
I have the 2 link ladder chains (with tensioners!) on this page;
tractor tire chains for farm tractors
on my BX 25 and have no clearance problems. There is not a lot of room to spare but they do fit. I did put extra springs on the tensioners as insurance, but there were no problems before. I'm using turf tires.
/ BX 25 tire chains #9
If you have any hills, definitely get the rear wheel spacers from bro-tek. It's like a whole other machine with them as far as lateral stability goes.
I have a BX25 with A4's (thanks Barlows!), 2 link V-bar tire chains (thanks tirechains.com!), and the rear spacers (thanks Rich@ bro-tek!) and skid plates.
The beast can climb trees with this setup.
I have tensioners on the front tires since there's less clearance with the steering up front, but on the rear wheels the chains are just cinched down pretty tight.
/ BX 25 tire chains
Thank you everyone for the help. I removed the tire and put the chain between the treads on the tire and tighten then down good. Its very close, but appears to work. Its strange that a tractor would have so little clearance for chains given the snow blower option is ready available. Its a great tractor though !!
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A66738)
2019 Mercedes-Benz...
KUBOTA ZD1511 ZERO TURN LAWN MOWER (A65057)
KUBOTA ZD1511 ZERO...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A66736)
2016 Peterbilt 579...
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
