Chains BX 25 tire chains
/ BX 25 tire chains #1
zleader
I am trying to install tire chains on a BX 25 but their is not enough room between the tire and the sub-frame, has anyone ran into this problem ?
/ BX 25 tire chains #2
Its pretty tight, but there is enough room for them to be run on. Currently I don't use them in the snow, only in mud.
/ BX 25 tire chains
have you had any experience with wheel spacers, my chains hit the frame ...
thanks
/ BX 25 tire chains #6
/ BX 25 tire chains #7
I have the 2 link ladder chains (with tensioners!) on this page;
tractor tire chains for farm tractors
on my BX 25 and have no clearance problems. There is not a lot of room to spare but they do fit. I did put extra springs on the tensioners as insurance, but there were no problems before. I'm using turf tires.
/ BX 25 tire chains #9
If you have any hills, definitely get the rear wheel spacers from bro-tek. It's like a whole other machine with them as far as lateral stability goes.
I have a BX25 with A4's (thanks Barlows!), 2 link V-bar tire chains (thanks tirechains.com!), and the rear spacers (thanks Rich@ bro-tek!) and skid plates.
The beast can climb trees with this setup.
I have tensioners on the front tires since there's less clearance with the steering up front, but on the rear wheels the chains are just cinched down pretty tight.
/ BX 25 tire chains
Thank you everyone for the help. I removed the tire and put the chain between the treads on the tire and tighten then down good. Its very close, but appears to work. Its strange that a tractor would have so little clearance for chains given the snow blower option is ready available. Its a great tractor though !!
1991 BRENNER TANK TRAILER (A67714)
1991 BRENNER TANK...
DEERE 410J Engine (A68134)
DEERE 410J Engine...
2012 DRAGON 165BBL ALUMINU VAC TRAILER (A67714)
2012 DRAGON 165BBL...
x (A68191)
x (A68191)
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
