BX-25 3PH Question
/ BX-25 3PH Question #1
Proletarian
North of Atlanta
BX-25 / BX-1830
After I'm done installing my sprinkler system using my back hoe I plan to remove it and install my 3PH so I can run my King Kutter XB tiller. Is the 3PH hard to install? anything special I may need to know? special tools, etc.. Thanks in advance.
/ BX-25 3PH Question #2
Not hard to do, just be sure to orient the lift arms correctly (they angle out) and have to be put on correctly (left and right sides).
/ BX-25 3PH Question #3
Looking at your avatar, I think it will be very hard taking the backhoe off and replacing it with the three point and tiller. ;) And is that what the new BX25s look like? Welcome to the group.
Take Care,
Doug in SW IA
/ BX-25 3PH Question #4
Easy, no tools...:thumbsup:
Putting implement on, need a 3/4" wrench and big adjustable.
thanks for the replies. Sadly I dont have the KX-91 digging monster anymore:( this crap economy slowed my business to a crawl and I had to sell it. was a sad day. the 3PH idea wouldent of worked anyway. :p
/ BX-25 3PH Question #7
It's easy to install. The only thing that threw me for a loop was a shiny brass bracket. You only put that on, if you intend to attach the top link with no implement.
/ BX-25 3PH Question #8
It's not that hard once you get the hang of it. If you run into any problems, be sure to let us know so we will be able to assist. :thumbsup:
/ BX-25 3PH Question #9
As I posted on another thread. Taking the back hoe off is a breeze. Installing the 3 pt is not a problem, BUT putting the back hoe back on was a two hour project. I had it on a BX expanded dolly and had to finally use two floor jacks to get it situated on the lower hinges . The rest was easy
/ BX-25 3PH Question #10
Check 6. Why two hours? why didn't you use the out riggers?
/ BX-25 3PH Question #11
I tried everything BUT you make a point I did not use the outriggers, I substituted floor jacks ...... oh well that is the price of having too many birthdays
2017 International Prostar 122 Day Cab (A62613)
2017 International...
YALE FORKLIFT (A63291)
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
