BX-25 3PH Question
/ BX-25 3PH Question #1
Proletarian
North of Atlanta
BX-25 / BX-1830
After I'm done installing my sprinkler system using my back hoe I plan to remove it and install my 3PH so I can run my King Kutter XB tiller. Is the 3PH hard to install? anything special I may need to know? special tools, etc.. Thanks in advance.
/ BX-25 3PH Question #2
Not hard to do, just be sure to orient the lift arms correctly (they angle out) and have to be put on correctly (left and right sides).
/ BX-25 3PH Question #3
Looking at your avatar, I think it will be very hard taking the backhoe off and replacing it with the three point and tiller. ;) And is that what the new BX25s look like? Welcome to the group.
Take Care,
Doug in SW IA
/ BX-25 3PH Question #4
Easy, no tools...:thumbsup:
Putting implement on, need a 3/4" wrench and big adjustable.
thanks for the replies. Sadly I dont have the KX-91 digging monster anymore:( this crap economy slowed my business to a crawl and I had to sell it. was a sad day. the 3PH idea wouldent of worked anyway. :p
/ BX-25 3PH Question #7
It's easy to install. The only thing that threw me for a loop was a shiny brass bracket. You only put that on, if you intend to attach the top link with no implement.
/ BX-25 3PH Question #8
It's not that hard once you get the hang of it. If you run into any problems, be sure to let us know so we will be able to assist. :thumbsup:
/ BX-25 3PH Question #9
As I posted on another thread. Taking the back hoe off is a breeze. Installing the 3 pt is not a problem, BUT putting the back hoe back on was a two hour project. I had it on a BX expanded dolly and had to finally use two floor jacks to get it situated on the lower hinges . The rest was easy
/ BX-25 3PH Question #10
Check 6. Why two hours? why didn't you use the out riggers?
/ BX-25 3PH Question #11
I tried everything BUT you make a point I did not use the outriggers, I substituted floor jacks ...... oh well that is the price of having too many birthdays
2022 EZ-GO ELITE...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2008 New Holland T2420 (A60462)
2008 New Holland...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
