BX 24
/ BX 24 #1
masterchief1
Greenfield Township,PA
BX 24
How much play is there supposed to be in front axle on a BX 24 Was doing some log lifting with forks on front bucket. No leaks or anything like that. Loaded on trailer and had some weight off front end when I grabed front axle, whole axle seemed to have a lot of play. Any thoughts would be appreciated.
/ BX 24 #2
On my BX there is a pivot adjustment in the center of the axle to control the play. I am supposed to check and adjust every 200 hrs or so.
You may have the same adjustment.
/ BX 24 #3
Mine would rock back and forth about a 1/4". Not up and down, forward and backward! I tightened that pivot bolt to the 15 ft lbs that was recommended and it took the play right out of it. (I may have gone to 20/25 ft lbs).
JLG 660SJ (A58214)
JLG 660SJ (A58214)
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2021 Deere 75G (A60462)
2021 Deere 75G...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
