BX 24
/ BX 24 #1
masterchief1
Greenfield Township,PA
BX 24
How much play is there supposed to be in front axle on a BX 24 Was doing some log lifting with forks on front bucket. No leaks or anything like that. Loaded on trailer and had some weight off front end when I grabed front axle, whole axle seemed to have a lot of play. Any thoughts would be appreciated.
/ BX 24 #2
On my BX there is a pivot adjustment in the center of the axle to control the play. I am supposed to check and adjust every 200 hrs or so.
You may have the same adjustment.
/ BX 24 #3
Mine would rock back and forth about a 1/4". Not up and down, forward and backward! I tightened that pivot bolt to the 15 ft lbs that was recommended and it took the play right out of it. (I may have gone to 20/25 ft lbs).
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
**SALVAGE ROW ENDS HERE** (A64280)
**SALVAGE ROW ENDS...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
