BX 24 Flail Mower
/ BX 24 Flail Mower #1
turkeyvulture
I'd like to get a 60 inch flail (Caroni or Gearmore) for my BX 24, but get all kinds of dire warnings about the consequences. Seems like you could manage the load on the tractor by controlling the mower height. Anyone have experience with this?
/ BX 24 Flail Mower #2
What are the warnings and the consequences ?
I was think of getting one for my B7800.
/ BX 24 Flail Mower
It will overheat.
It will blow the transmission.
It won't have enough power.
The width will exert racking torque on the 3PH and wear it out.
You should never put something on there that's wider than the wheel track of the tractor.
I've never seen anyone do that, a 48" flail is as wide as I've ever seen.
Etc, etc.
Cripes I'm tempted to do it just out of contrariness.
/ BX 24 Flail Mower #4
I run a landpride 5' flail on a B2910 (same engine as B7800). It will bog it down pretty easy. Just have to take it easy. Have thought of trying on BX for compact size. Haven't checked the weights yet. I know it's heavy.
/ BX 24 Flail Mower
Funny thing is, Kubota makes a 60" wide mid-mount mower for the BX24. If the BX 24 can turn that, why can't it turn the 60" flail just as easy?
/ BX 24 Flail Mower
Thanks Blue Power. Is that due to energy loss in the mechanicals, or because the flail is chopping the material up finer, or both?
/ BX 24 Flail Mower #8
When I use my 48" flail on tall grass it will bog it down unless I really slow her down. Invariably, the cutters will be dull. Too many cutters to sharpen very often.
/ BX 24 Flail Mower #9
Thanks Blue Power.
Not trying to hijack the thread here:
No a flail mower does not require more mower than a rotary mower with belt drive
Power use is less and the energy used rotates more cutting edge than a rotary mower
because only half a rotary mowers blade/cutting edge is contacting the grass or brush to be cut.
A flail mower will leave hardly any clippings and you can mow over them and shred them even finer
due to the pressure gradient created by the lift created by the side slicers of a finish flail mower.
A flail mower depending on brand, end use and final pulley diameter
rotating the flail mower rotor will reach 2,200 RPM or more.
A rear mount flail mower for receives it power from a 540 RPM power take off
where it is delivered to a right angle gearbox which then transmits this energy
to the drive pulley with then delivers this power with V belt to the larger in diameter
driven pulley which rotates the flail mower rotor which spins up to 2,200 rpm or greater depending on
the intended use being mowing, crop shredding, forestry mowing etc.
Depending on the number of knive stations and whether it is a finish cut flail
mower you will have much more cutting edge slicing the grass blades with the
following row cutting more grass as the mower advances or reverses.
My four foot finish cut flail mower has 64 knife pairs and each side slicer has 3 inches of
cutting edge with 6 inches of cutting edge in one side of the knife pair and 384 inches of
cutting edge on one side of the knive pairs so think about that issue when you look at a
rotary mower or rotary brush mower when you are looking at a rotary mower that has a
five foot width (NOT WIDTH OF CUT)
Oh and a flail mower pr flail chopper only has two bearings that support the flail mower rotor
versus a bearing stack on the rotary mower or brush mower spindle
A mid mount mower will have a mid PTO that is rotating at 2,000 RPM plus or minus
to a right angle gearbox which then delivers the force to the three pulleys/spindles
via V belts which rotate the spindles and the blade tip speed is what does the massacre
of good turf tearing the grass blades.
/ BX 24 Flail Mower #10
Had a HD 60" on a mx5100 (50 hp area) and on larger hills I could feel it pulling the power down even with new flails. I was not impressed with it and went back to a regular brush hog as it used a lot less power for the width it cut..... My BX would not even lift the flail I had let alone run it.
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
2020 Hino Garbage Truck (A60352)
2020 Hino Garbage...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
MASSAGE CHAIR (A58214)
