Buying Advice Buying my first tractor....
/ Buying my first tractor.... #1
Hobart15
Georgia
N/a
Have about 150 acres. Looking for a tractor for general land management and about 12-15 acres of food plots. Thinking of getting a yammer 3810d with a loader from fredricks....or finding a used Kubuta 40- 50 hp with a loader.
Land is pretty flat with some rolling hills. I'd have a small creek.
Am I on the right path? Any suggestions?
Thanks
Bill
/ Buying my first tractor.... #2
I'm not familiar with the Yanmar 3810d, but for 150 acres I'd sure want something bigger than a 40 - 50 hp tractor unless most of the acreage will be left alone. I'd be looking at the 70 - 80 hp range depending on the intended uses of it.
I wish I could be more helpful, but "general land management" doesn't tell us much. Give us some specifics if you can.
/ Buying my first tractor.... #3
I would look for 40hp plus,have you consider rear attachments...rake,mower,blade.
Ok, let me be a little more clear. This is for a hunting camp. No $ crops other than about 45 acres of planting pines. There is a pretty good road system that needs mowing. Plan on having about 12-15 acres of food plots that will need to be planted and maintained; one 4-5 acre plot and Will also use it for maintaining Fire breaks.
Most people are telling me 40-50 hp pulling 5' attachments.
/ Buying my first tractor.... #5
You are close;40-50HP ,four wheel drive with six ft.implements.
/ Buying my first tractor.... #6
Ok, thanks for the additional info. Yes, what nybirdman said. 40 - 50 hp, 4wd with 6 foot implements.
The general rule of thumb for PTO driven implements like rotary mowers is that you need 5 PTO horsepower for every foot of width. So you would need a minimum of 30 PTO hp to run a 6 foot wide cutter. But it's best to have a a little extra hp as a margin of error, which could mean the difference in bogging down or powering through some tall, thick stuff when mowing. My Kioti is 50hp (gross) and 37.5hp (PTO) and runs my Rhino 172 medium duty mower just fine with no stress or strain on the tractor.
/ Buying my first tractor.... #8
I have just recently purchased my first tractor and bought a Branson 5520R turbo. It is a well built heavy tractor for a CUT. I have just recently been able to put it to the test pulling a 7 tine chisel plow to break up a garden spot that hasn't been plowed in over 25 years. I had to work in 4 wheel drive and fill the fel with dirt to keep the wheels from spinning and it was all it wanted but it pulled it. I was pleasantly surprised.
I mention Branson because I noticed you are from Georgia and Branson's main hub is located in Rome, GA. A contributing factor in me choosing Branson was that I have a dealer very close to me. Dealer support is important. Just my 2 cents worth.
/ Buying my first tractor.... #10
I take it that the Yanmar is used as they stopped making that model number in 1981 as per tractor data.com. It sounds a bit light at only 2921 pounds and narrow at 58 inches wide not adjustable. There are plenty of good options both new and used in that horse power range so I would take my time and sit on and test drive a few to find one you like.
/ Buying my first tractor.... #11
Look at a Kioti diesel, 4 wheel drive. Like most diesels, it's simple to service and would match up with what you need and comparing it to a comparable Kubota, will leave a significant amount of cash in your pocket!
P.S. Don't be confused by my current rig. Sold my 46 acres, bought another and leased it. Now all my tractoring is on a John Deere lawn tractor😂
2014 Massey Ferguson 8650 Tractor (A63111)
2014 Massey...
(INOP) 2022 POLARIS RANGER 500EFI RTV (A64280)
(INOP) 2022...
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
2 Row Cole Planters w/Plates (A64119)
2 Row Cole...
2025 Auger Drill Bit Mini Skid Steer Attachment (A61572)
2025 Auger Drill...
