Buying Advice
/ Buying Advice #1
db05
Looking for a tractor in the 30-35 HP range with 4x4. I've decided to go with the makes below. I'd like to have a Deere or Kubota, but price prevents. I would very much appreciate your opinions, comments or any other info concerning the makes below. I guess the main info I need is, is there any big difference between the makes and are parts easier to find on some?
Yanmar
Mitsubishi
Iseki
Lenar
Hinomoto
Mahindra
Once again, all opinions are much appreciated.
/ Buying Advice #2
Yanmar
Mitsubishi
Iseki
Lenar
Hinomoto
Mahindra
i was in the same boat as you... .at first i was hopeing to get a 10K tractor, but everything i could find in that range was used Grey market stuff and usually not in the size i wanted.
I ultimatly went with a used NH and am very happy i did.
Of the above i would Recomend Mahindra or Kioti (not on your list) as they seem to be the most prevlant and therefore easyest to find parts for. (least that would be my logic....)
/ Buying Advice #4
I've had my Mahindra for 3.5 years and love it. Don't think you can go wrong with this red one.
/ Buying Advice #5
I can't speak for every part of the country, but here in LA, the Mahindra's weren't much cheaper than the Deere and Kubota for a unit in the hp/feature range you mentioned. I bought my tractor in the last month and I shopped around thoroughly at all the "bigger name" tractors.
I was on the Mahindra "lot" and when I heard the Mahindra's price, I almost fell out of the seat! :eek: My thoughts exactly were "I can add just a little to that and get a Kubota". I'm not knocking Mahindra, people around here that have them, swear by them. If I didn't care for the brand, I wouldn't have been on the "lot". My issue is there aren't many Mahindra dealerships around here and what happens if they were to go out of business? How far would I have to drag the tractor for regular maintenance or a breakage, seeing as how my mechanical inclinations make tightening a bicycle chain an all day affair?
To summarize and get off my proverbial soap box, strike Mahindra off your list if $ is an issue. They aren't cheap!
/ Buying Advice #6
I don't know where you are, but around here even Mahindra is kind of a long ways to a dealer. We had a guy start up, but now he has no tractors on the lot. The others aren't even seen.
Your choice should be based on what is available around your area, for both sales and service/parts. Even if you do a lot of your own mechanical work you will need parts now and then and a dealership is pretty important to have handy.
I'd side with majority and suggest finding something used. 30 to 35 hp is big enough that there should be things around like Massey 135s, various Fords, and other old farm brands for fairly good prices. N series Fords that will do a lot of work can be had for less than $5k easily. Some fairly big iron is available surprizingly cheap since farmers have moved up to huge stuff and CUT buyers want smaller stuff.
My SIL just bought a 70 hp tractor in good working order. I'm pretty sure he paid less than you want to spend. With something of that size you probably won't need 4 x 4.
/ Buying Advice #7
Yanmar
Mitsubishi
Iseki
Lenar
Hinomoto
Mahindra
Hmmm, you like JD but now are looking at Yanmar.
I assume you are aware that there are JD tractors in your hp range that have Yanmar engines (JD4610, JD 4710). These two models were last built in 2004 and the average retail price for the 2004 models (dealer's price for a "clean" used tractor) is in the $18-21K range.
/ Buying Advice #8
I have a Branson and have been very happy with it, I don't know if you have a dealer in your area?
/ Buying Advice #9
What's your price range? Do you need an FEL?
The Kubota L3400 is basic but solid and around here not very expensive. JD 790 and 990 (both made by Yanmar, I think) would also be worth a look, though prices will depend heavily on dealer and the norm in your area for green paint. Also New Holland TC30 might be worth a look - another basic one from a major brand (and I think made by one of the Japanese companies).
/ Buying Advice #10
I am suprised no one has asked what you plan to do with this tractor. I think that plays into it a lot.
/ Buying Advice #11
I was just about to ask that and also what area of the county (he lives in) might have an impact on the price.
/ Buying Advice #12
I did the same thing 4 years ago, went with a Chinese tractor, to work on my land before my house was built. However, once my house got built, I needed more reliability and quicker service so I bought a NH after narrowing down my choices to NH, Kubota, JD. The Chinese tractor decision was made based on available funds at the time and was good at the time but now I don't have the time to work on it and deal with delays in getting it fixed.
Want to buy my old one :D
/ Buying Advice #13
Yanmar
Mitsubishi
Iseki
Lenar
Hinomoto
Mahindra
Take a little test. Write down these brands and any others you can think of. The write down a list of common maintenance parts and repairs. Things like oil filter, fuel filter, Air Filter and Hydraulic filters. Starter, Fuel Pump, Alternator and a Fuel Injector. These are all things you can reasonably expect to need at some point.
Now try to find those parts for each machine your interested in. Can you ge them at Napa or is there a dealer near you? Can you find them online and do you want to wait weeks for them to get to you?
I chose my brand because I can get parts for it when I need them. Your tractor will break down. It doesn't matter if it's brand new and cost $30,000 or used and was for free, it will happen. The question is wether you can fix it or will it become yard art?
Eddie
/ Buying Advice #14
I got my Kubota L4400 because it was the cheapest tractor in its HP range that I could find at local dealers. Granted, there were not many dealers around with Chinese machines. However, I think the L4400 is still among the cheapest. It cost a little less than the comparable JD 990. I think the L3400 (most basic version) is also very affordable for what you get. I think the JD 790 is significantly less tractor than the L3400. So don't write Kubota and JD off just because you assume they cost a lot more. And compare apples to apples. Some of the off-brand machines cost as much as the L4400 but they did come with more frills. With my budget I was after hp, not frills.
/ Buying Advice #15
I have a grey market Yanmar. Most models have very good parts availability. Bear in mind Hinomoto is no longer in business though some parts can be found at AGCO dealers. Before buying any grey market tractor, either buy from a reputable dealer such as one who frequents this forum or at least make sure it is a model for which parts can be found and for reasonable prices. There are more grey market Yanmars in the US now than Yanmars that were originally made for this market. The right grey market tractor can be a great purchase as far as price, reliability and dealer support.
/ Buying Advice #16
I shopped around plenty and save thousands by going with my Mahindra over a comparable model JD, Kubota, NH, or Massey. Prices at one dealership, or even prices given by one salesman do not make universal facts.
The Mahindras are good tractors, and making a bigger name for themselves here in the US every day. The Kiotis are doing the same thing. In general with these tractors you get a lot for your money. My Mahindra has standard features that the barebones models of the big three do not have.
2005 Sterling L7500 Fuel and Lube Truck, VIN # 2FZHATDC95AV42993 (A61165)
2005 Sterling...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2015 International WorkStar 7500 T/A Dump Truck (A61568)
2015 International...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2015 Chevrolet...
Champion Vibratory Roller (A60462)
Champion Vibratory...
80in Bucket Skid Steer Attachment (A61567)
80in Bucket Skid...
