Buying Advice on Hydraulic links
   / Buying Advice on Hydraulic links #11
I use a hyd top link on my Ford. TnT on my Kubota. A tractor without either is very limited. Both is the way to go if your tractor can support them.
Post pics of your setup when you are done.
   / Buying Advice on Hydraulic links #12
I think Fit Rite is quoting 30 weeks for delivery now… so that’s not an option. Hope to have a top link in the next 6 weeks for some road work
The top link is standard and easy to find. The tilt link is neither of those.
I'd buy a generic top link and order a tilt link from Fit Rite.
   / Buying Advice on Hydraulic links #13
I mean the HYD top link. Of course it has a standard top link. I won’t wait 30 weeks for a HYD top link when others can ship tomorrow.
   / Buying Advice on Hydraulic links #14
I decided to add a DPCV top link to my Ford. I ordered one thru Amazon. $270-ish. Ordered it yesterday. Will get it Friday.
   / Buying Advice on Hydraulic links #15
I’ve been looking at a crank version for one side of my height adjustment. Much cheaper and I don’t need to do it often, just often enough that a turnbuckle is a pita
   / Buying Advice on Hydraulic links #16
Beenvenue - a shame we are so far apart. I was given a hand crank unit. Never used it. I would give it to you. I think this may be what you are looking for.
I'm getting 2 remotes regardless of which model I get. They are standard on the T494 and will get added to a 4820. Sorry for the confusion, I knew the OEM didn't make them, but a good dealer can source parts cheaper than an individual and installation for an expert is faster and better (I know my limits).
Now I need to figure out exactly which links will fit.
   / Buying Advice on Hydraulic links #19
If you plan to use a hydraulic top link and/or a hydraulic side link, get 3 rear remotes if possible. You'll wish you had.
Do tell? Why? One for up/down, one for side to side....do I need one for paint the fence?
The T494 is already set up for the 3rd function, so you don't lose one if you jury rig it..
What am I missing?
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
(4) ALUMINUM RIMS FOR KAWASAKI MULE (A58374)
(4) ALUMINUM RIMS...
1646 (A58375)
1646 (A58375)
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A56857)
2025 JMR Single...
6' LANDSCAPE RAKE, 3PT (A52708)
6' LANDSCAPE RAKE...
CAT 312C EXCAVATOR (A58216)
CAT 312C EXCAVATOR...
