Buying Advice on Hydraulic links
   / Buying Advice on Hydraulic links #11
I use a hyd top link on my Ford. TnT on my Kubota. A tractor without either is very limited. Both is the way to go if your tractor can support them.
Post pics of your setup when you are done.
   / Buying Advice on Hydraulic links #12
I think Fit Rite is quoting 30 weeks for delivery now… so that’s not an option. Hope to have a top link in the next 6 weeks for some road work
The top link is standard and easy to find. The tilt link is neither of those.
I'd buy a generic top link and order a tilt link from Fit Rite.
   / Buying Advice on Hydraulic links #13
I mean the HYD top link. Of course it has a standard top link. I won’t wait 30 weeks for a HYD top link when others can ship tomorrow.
   / Buying Advice on Hydraulic links #14
I decided to add a DPCV top link to my Ford. I ordered one thru Amazon. $270-ish. Ordered it yesterday. Will get it Friday.
   / Buying Advice on Hydraulic links #15
I’ve been looking at a crank version for one side of my height adjustment. Much cheaper and I don’t need to do it often, just often enough that a turnbuckle is a pita
   / Buying Advice on Hydraulic links #16
Beenvenue - a shame we are so far apart. I was given a hand crank unit. Never used it. I would give it to you. I think this may be what you are looking for.
I'm getting 2 remotes regardless of which model I get. They are standard on the T494 and will get added to a 4820. Sorry for the confusion, I knew the OEM didn't make them, but a good dealer can source parts cheaper than an individual and installation for an expert is faster and better (I know my limits).
Now I need to figure out exactly which links will fit.
   / Buying Advice on Hydraulic links #19
If you plan to use a hydraulic top link and/or a hydraulic side link, get 3 rear remotes if possible. You'll wish you had.
Do tell? Why? One for up/down, one for side to side....do I need one for paint the fence?
The T494 is already set up for the 3rd function, so you don't lose one if you jury rig it..
What am I missing?
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
LOT OF WOOD FLOORING (A58374)
LOT OF WOOD...
SHOPBUILT T/A TRAILER (A52708)
SHOPBUILT T/A...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
