Buying Advice Buying a Zero-Turn Mower
/ Buying a Zero-Turn Mower
Well, I've got a lot of specs to watch now. The problem is I have no idea who makes ZTRs. What are the brands out there? I know Kubota and JD, I think Ferris, Exmark, Hustler, and some others have been mentioned. Husqvarna also usually comes up on my searches, what's out there?
/ Buying a Zero-Turn Mower #44
Include Grasshopper in your list.
/ Buying a Zero-Turn Mower #45
These are the main brands I'd consider, in alphabetical order
BadBoy
Bobcat (not Bobcat construction stuff, these are green)
eXmark (or Toro Pro, same company)
Ferris (or Snapper Pro, same company)
GrassHopper
Gravely
Hustler
John Deere
Kubota
Scag
Wright
I may have missed a few...
/ Buying a Zero-Turn Mower #46
Are you guys trying to tell me that there are no reasonably priced new mowers capable of handling 7 acres of relatively easy lawn mowing 20 times a year (that's what, 50hrs a year?)? Because I find it hard to believe I'll have to pay 8K+ for something to do that. If that's true, I'm thinking a RFM for the Kioti might be the way to go. That'll only cost 3-4K max. There has got to be a grade between $3000 residential mowers, and 8K bottom line commercial mowers.
Go visit Michigan Iron and equipment east of Perry Michigan.They carry ferris ZTR mowers.The starting price is around $5000-$6000 for a decent ZTR.
/ Buying a Zero-Turn Mower #47
I'd MUCH
I LOVE my Grasshopper 61" front deck, the Kubota diesel, uses less fuel and will easily out last any gas motor...
SR
or 3 or 4 gas motors
my neighbor has a 21hp diesel grasshopper 61" compared to my 22 hp 52" gas turd cadet RZT the torque rise of the diesel is awesome does not bog down in the tall grass like mine does. the front deck true zero turn is nice as opposed to the kubota f Series which is basically a tractor driven backwards to wide of a turning radius.
I would never ever buy another $3000 machine but it's what I could afford at the time. I hated it ever since
Neighbor has a hustler prosumer machine with kawasaki fx engine very nice build.
currently looking at zd326 or the new Zd1211. I'm sold on the diesel. I've ruled out the Ferris and John deere for price. Haven't seen much on the hustler diesel but the styling is unappealing to me.
/ Buying a Zero-Turn Mower #48
Yuck! No offense, but the fit/finish of these aren't as nice, in my opinion, as the other major players.
Personally a think the Dixie choppers are pretty nice. I have a Silver eagle. IMO it is far superior to my uncles commercial Toro. If I was going to trade my Dixie chopper it would take a Kubota diesel or a front deck diesel grasshopper.
/ Buying a Zero-Turn Mower #49
interesting... To me, the Dixie models seem like they haven't made it out of the 1980s yet
/ Buying a Zero-Turn Mower #50
I'd MUCH rather have a wider deck and go slower than a narrower deck and go fast...
I do not find my 61" decks to be too wide for "some what" rough ground, my lawn sure isn't perfect, and I mow my lanes and around my orchard tree's with mine.
SR
I second the vote for a front mount Grasshopper. I bought a used Grasshopper 721 with a 20 HP Kohler and 61 inch deck 2 seasons ago with 700 hours for $2100. Can't imagine mowing on anything nicer. What a machine! Great cut. Great maneuverability. I mow 7 acres with it regularly. Takes more like 3-4 hours though because I have lots of trees, landscaping, etc.
/ Buying a Zero-Turn Mower #51
What part about the Dixie chopper do you don't like? You can choose between a Kohler, Vanguard, or Kawasaki motor. I haven't seen a ZTR with with a heavier duty frame. They have a heavy duty fabricated deck ( which is no better or worse than other decks ). Some models offer a gas, diesel, or propane engine. Some other brands have a faster top travel speed ( which I guess means they aren't the worlds fastest mower ). My Dixie chopper still goes fast enough to bounce you off so I don't think maximum travel speed is very important.
/ Buying a Zero-Turn Mower #52
OP, how many obstacles do you mow around on that 7 acres? If the majority is wide open how about a finish mower behind your Kioti, maybe that's been suggested. What can it handle, 6ft.? The rest around the house could be handled by a lot less mower than a full blown commercial mower.
Kevin
/ Buying a Zero-Turn Mower #53
BadBoy
eXmark
Ferris
GrassHopper
Gravely
Hustler
John Deere
Kubota
Scag
Toro & Snapper Pro Models (same company as eXmark)
Wright
Walker :)
/ Buying a Zero-Turn Mower #54
I apologize, I meant that about the Grasshopper units (dated). The few Dixie units I checked out seemed unrefined and "thrown" together. That was a couple years ago though.
/ Buying a Zero-Turn Mower #55
Nothing to apologize for. I was just asking for a little explanation.
/ Buying a Zero-Turn Mower #56
Kevin
The CK 35 should handle a 6' finish mower easy, and would probably run a 7'.
I run a 7' rear discharge rear finish mower on my DK 35 and it handles the mower, no problem.
/ Buying a Zero-Turn Mower #57
I am a large toro fan we have had one for 12 years with 60in deck mows very well one belt two front tires in that time having been replaced. I did replace the motor last year for more power and EFI. Original motor was 23HP now 27. Our front yard is a 17 degree slope no problems. Change oil grease and sharpen blades that's about it. Purchase price was 7695 now over 11000 dollars.
We mow 4 acres at our house and at another location mow 1.4 acres and it is more than up to the task. This model was a professional model or commercial whatever was in vogue at the time with 23HP instead of 27HP everything else the same. My recommendation is to go with the best you are willing to spend but commercial models are the way to go in my opinion
/ Buying a Zero-Turn Mower #58
Pretty good list. Notice Cub Cadet is not on the list. I like John Deere,Scag and Grasshopper, but the others make good products as well. Snapper Pro,Gravely and Bad Boy give you a lot for your money if you have a good dealer near.
/ Buying a Zero-Turn Mower #59
I run a 6' mower with my b7100 with 14 pto hp, but it isn't nearly enough. My L3240 handles a 6 foot mower with ease.
If I went the RFM route, it would be 6ft minimum, maybe 7. The Kioti would have no problem with either. My land is not wide open. Some parts are an obstacle course, there are some open areas, around the house there are a lot of flower beds that curve in and out (the previous owner was a gardening nut, I've pulled out half the beds, else I'd need a fulltime gardener). The reason I don't want to go that way is because I bought the tractor to be tractor, maximum traction, heavy, etc. Most of the time it would kill the lawn. The other reason is maneuverability. While the RFM would be better than the H's mid mower, I think I still would have to have something smaller to get in a couple real tight spots. An example is in back of the house, where the mower has to deal with the contours of the flower bed, the patio, the birdfeeder, well pump head, birch stump, and two small trees. While there is plenty of clearance for a 60" or 72" deck, even without the loader, it would be a real pain to get the tractor in there.
The best option actually would be a SCUT with MMM and loader, that could get in tight areas and do landscape work on the lawn without bringing in the Kioti. But I'm not spending the 18K for another tractor. The same applies for the front mowers. While they might be useful, I'm afraid they are out of the budget. A zero turn will work just fine there, no need to pay 5K more.
I'll sit down and go over specs this weekend, look at brands online, see what's out there. I have time on this, and I plan to use it.
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
iDrive TDS-2010H...
2019 John Deere 712C Cornhead (A63111)
2019 John Deere...
2015 Toyota Tacoma Ext. Cab Pickup Truck (A61573)
2015 Toyota Tacoma...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
