Buying Advice Buying a tractor
/ Buying a tractor #21
12 gears forward, 12 gears in reverse, synchro shuttle. A compact tractor gear transmission that should be able to creep.
I assume no foot clutch.
/ Buying a tractor #22
It does have a clutch...
4 Gear and 3 Ranges. It will creep. It's a very common transmission.
/ Buying a tractor #23
Yep 12x12. 1st and 2nd in low are definitely creeper gears... I can feel my beard growing...:D. In low range, you can just use the hydraulic shuttle shift without using the clutch, in medium and high range, using the clutch is definitely easier. For loader work, most of the time I am in low range, either 3rd or 4th gear. With soft piles, medium range 1st or 2nd is still ok.
When I just cut the fields, med. range and 3rd was the ticket... there are definitely enough selections for sure!
The reason I primarily went with gear was to avoid the HST PTO HP loss.... basically 2 HP. I was initially worried about not getting the HST, but it was unfounded. The gear tractor has worked out fantastic for me.
/ Buying a tractor #24
Yes, definitely a clutch (on the left) and also split brakes (on the right).
/ Buying a tractor #25
I don't think that tractor have a Hydraulic Shuttle shift, just a regular mechanical Shuttle shift. At least it doesn't show up on the website for the specs.
Shifting without the clutch won't do any good on the syncronizers of the transmission.
I think those 2 HP at the PTO difference, on paper, between Geared and HST, turns out to be more in the real world application. Let's say you're mowing uphill, the will HST bog down much easier/faster and will eat much more HP for the HST than the Geared, which will carry on.
/ Buying a tractor #26
I would have to say, 9.5 times out of ten, I do use the clutch. When I was discussing the shuttle shift with the dealer, he did tell me it was hydraulic, but not like the true hydraulic “ power shift “ on the larger machines. He also recommended using the clutch for “ full motion “ change of direction. When just inching forward or backward, you can just feather the shift lever (not actually moving it into the notch) and the tractor will just move ever so slight. Makes it really easy to hook up implements or the BH.
/ Buying a tractor #27
Hey guys,
Looking at buying a tractor for my place. I have a few acres that I need to move a bunch of dirt around and then going to make some pasture area, and garden areas I have about 1000' of gravel dirt driveway. Winter time will be moving snow.
My question is I'm looking for operational feedback on some tractors with FEL.
I have a list of possible candidates all prices after tax and financing charges come out at around 20k +/- 1k.
Branson 2400H 21k dealer 10min away.
Kubota B2601H 20k. Dealer 30min away.
Kioti CK2510H 19.5k Dealer 45min away.
TYM T264H 20k. Dealer 1hr away.
LS XJ2025H 18.5k. Dealer 1hr away same dealer as the TYM.
I think my short list is either the Kioti #1 or the TYM #2.
All the dealers have been responsive and helpful and have been around for a while with the exception of the Branson.
We have several JD, Massey, and case dealers within 30-45min also. Some are carrying the above brands.
The JD, Massey and case are about 5-10k more for a similar tractor.
Any thoughts or comments would be much appreciated. Mostly just looking for experience with the different models. I know dealers are important and that has been factored into my short list.
Thanks!
You might want to check the Kioti CK2610, you get 3 ranges, more weight, better loader for not much more $$$ when compared against the CK2510.
/ Buying a tractor
Did you look at the LSMT225e? Much more tractor / weight, more suitable for what you describe doing. Another plus right now is LS just announced financing at $0 down, 0% interest, 84 months.
Actually the financing is 0% for the first 90 days then it will incur interest. It's in the fine print.
/ Buying a tractor #29
/ Buying a tractor #30
Apparently that deal went away on the 28th.... it was no payments for 90 days, 0% interest. Now it is just “ low rate “ financing unfortunately. The other sneaky thing was “ free loader OR 0% financing “. So you are basically paying the interest when you “ buy “ the loader.
They are still offering the free loader though.
/ Buying a tractor
Ya they all do that. Free loader or 0% or 15k with regular financing and 18k with 0% financing. It's goofy.
/ Buying a tractor #32
I finally bit and bought an LS MT125 last year.
I looked at several brands, narrowed it to LS and Kioti. I was pretty much committed to Kioti until I sat on the LS. Things I thought might bother me didn't, and getting on and off the platform was a breeze. With a few other tractors, my feet might catch a lever or knob, a lever might be sticking in the back of my calf, or my knees just didn't fit right around the wheel. I am a big guy, 6'4, 275lb, in good shape.
I went away from the 2025 because of the backhoe versus MMM interference.
I ordered the MT125 with the backhoe, the FEL with QT, the MMM, and a front end snow blower with hydraulic chute control. Also got a set of QT pallet forks.
Your driveway is a bit longer than mine, I'm at 900'. Plowing is impractical because of retaining walls along the sides of the driveway for several hundred feet. The LS replaces a JD GT235 with a 44" Bercomac snowblower, I used that for the previous 15 or so years for mowing and snow removal.
I did a lot of earth moving last summer. Dug a 6' deep cut into a slope, used that to fill in the lower part to level the area. I've moved maybe 50-60 tons of stone for stonewalls with the FEL. Dropped several trees, used the pallet forks to move the wood. Used the backhoe to dig out stumps.
I have a 12" backhoe bucket. The backhoe is small, but it gets jobs done. I knew it going in, but the limiting factor for me with the backhoe is the side-to-side swing. It's not 180 degrees like some others. It would have been nice, but again, once you get it, you work within it's limitations. I'd like to have a larger bucket, but it comes down to earth penetration, etc.
The QT for the FEL does cost me some lift capability as the bucket is a bit further away from the pivot points. But again, you go with the flow.
I've talked about the limitations. But it has abilities too. I've worked this tractor, I have zero regrets buying it.
One other thing that lead me to the MT125 was the MMM. It's easy ON/OFF, and I mow a couple of grass lawns on my property, so I a smaller tractor to minimize soil compaction. It mows quite well, and mowing is much quieter than with my old JD GT235. As soon as I mounted the front end snowblower, I stood back and remarked, "well, now that THAT is on, I've guaranteed no snow this year." And yup, nothing more than a couple of light dustings this year in southern CT, so I haven't used the blower to date.
The dealer did fill the tires. I've had no issues with imbalance or tipping with all the earth and stone moving I've done.
I had an very inexpensive "soft cab" on my GT235 for blowing snow. LOVED IT. I initially ordered the MT125 with the factory cab, but when I ordered, I found out the factory cab AT THAT TIME was not compatible with the backhoe. The dealer said they are working on a modification. IF they don't come up with something, I'll probably DIY a cab for winter use. Based on my experiences with the soft cab on the GT235, I don't need fancy. I just need a roof and walls to break the wind and to keep swirling snow off me.
I will remark that not having a cab makes it easier when driving around trees. No worries about a branch taking out a window.
Good luck with your search.
/ Buying a tractor
Well I drove around all morning checking several different models. One dealer also sold yanmars and I drove a SA324 didn't like it much but it had a roomy operators station. Lots of plastic on it though and the loader seemed pretty flimsy.
I ended up getting the Kioti. The one thing I don't necessarily like about it is the treadle for the HST I played around with it for about 30min or so and after a little seat time I felt I could get used to it. Some of the others were nicer in some areas and not so much in others. The thing that stood out to me the most on the Kioti was it felt much tougher and more solid. It is built a lot heavier in a lot of areas. The other thing was the loader control. It was a lot smoother and more refined and could be feathered easier to lift and curl at the same time. Most of the others it was either or and they also seemed to take a lot of finesse to prevent the all or nothing when moving the bucket.
The dealer had come down quite a bit on price since last month which was also a contributing factor. I got the tires loaded, a cutting edge for the bucket and all the filters for the first service. Out the door cost before tax was $14,500. Total with tax and insurance (@$10mo) was $16,400. Darned taxes! It includes free delivery and free implement rental 5 times a year for up to 10days for 5yrs. That'll give time to see what I'll need without be pressured to buy a lot of stuff right away.
Should be here tomorrow or Thursday depending on when they get it back from getting the tires filled. Just in time to break it in this weekend!
Thanks everyone for the input! This is great resource!
/ Buying a tractor #34
Kubota and the Dealership has served me well, including some specific modifications for my particular needs. They have a loyal customer in me. Prior to my purchase, I looked at many other brands also, but once you decide on Brand, then required features and resulting Model(s), ... the rest is easy. All the best.
Kioti was comparative, but you hit gold with this ... "It includes free delivery and free implement rental 5 times a year for up to 10days for 5yrs. That'll give time to see what I'll need without be pressured to buy a lot of stuff right away."
That's awesome :)
/ Buying a tractor
Yes I was definitely surprised when they mentioned the rentals, they didn't say anything until I told em I would buy it. We were pretty busy sharing old military stories though so he probably was distracted a bit from trying to actually sell something. Haha.
/ Buying a tractor #36
It includes ... free implement rental 5 times a year for up to 10days for 5yrs. That'll give time to see what I'll need without be pressured to buy a lot of stuff right away.
That's a perk I haven't heard of before. Guess it depends on the items available when I would need them.
/ Buying a tractor #37
jeff9366 - BRILLIANT RESPONSE, I agree
/ Buying a tractor #38
Ive never heard of such a thing.....but its a GENIUS move.
Implements are sturdy and not easily broken.....so they are going to be able to use them and sell them as used - lose very little on resell but gain the rental income.
Plus a nifty perk to give new buyers.....you get to try, they get MORE chances to sell you something.
Someone at that dealership needs a "thattaboy" for such an idea.
/ Buying a tractor #40
Question, you got the ck2510 or the ck2610?
Congrats by the way.
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
2022 EZ-GO ELITE...
Club Car Emergency Cart (A64557)
Club Car Emergency...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
