Bush Hog flex link needed!
/ Bush Hog flex link needed! #1
jpsmittyman
NC
I have a older Bush Hog rotary cutter I purchased recently. There are no stickers or plates showing model number of this cutter. It is missing the flex link or “C” bracket on the top link and I am having a difficult time locating one to purchase. Any help on same would be helpful. This is a very older model cutter.
/ Bush Hog flex link needed! #2
If you can't find or fabricate one, ditch those flimsy bars from the top link pin to the rear that they put on those brush cutters. Replace with 2 chains and then hook the top link to the top link pin on the A frame of the cutter. You'll still have the same effect as the flex link, except with a lot more movement.
Similar to this:
/ Bush Hog flex link needed! #3
Have. Photo or two of the rotary cutter available and call Bush Hog and ask for their assistance.
/ Bush Hog flex link needed! #4
I've seen those cutters with the chain links to the rear of the deck and notice that the manufacturer of the rotary cutter I have still uses solid straps with a pivot at the 3pt toplink location. It is said to allow 15 degrees of movement at the rear. I understand what it is trying to accomplish but do chain links allow too much movement on rugged terrain possibly running the front of the cutter into the ground? Is the main advantage of using chain cost?
/ Bush Hog flex link needed! #5
My concern with the chain setup is that you could potentially over angle the joints in the pto shaft, resulting in a catastrophic failure under load.
/ Bush Hog flex link needed! #6
A cousin did that mod, then cut a length of water pipe to fit over the chain to limit movement so that would not happen. Shoot, that was perhaps 25 years ago.
One can accomplish the same thing by cutting off a section of the OEM steel straps and inserting a short length of chain on one end.
/ Bush Hog flex link needed! #7
It takes a lot for those U joints get on a bind. I've pushed mine so far up, it was close to 80 degrees and still wasn't even close to bind any of the joints.
I could still raise mine a bit more in this picture. Now imagine reversing to an embankment, it will push that cutter even further up.
Does anyone know where to buy the flex link? That is the information I was looking for.
/ Bush Hog flex link needed! #9
I had located this part but from the pictures I don’t see the metal tab that keeps the attachment from moving to far. I may have to try this, for it would be better than what I have now. Thank you for the response.
/ Bush Hog flex link needed! #11
What attachment are you talking about?
That link is designed to be able to flop over center. And can be a real pain to hook up.
It is not quick hitch compatible.
Yes I have figured out that now. I did order this part from Messick to try. Thanks
/ Bush Hog flex link needed! #13
Mine is. It's more of a stirrup or yoke. I have mine mounted between the top cylinder and the quick hitch. That way, it's always there for any implement or mower I happen to be using. The 3ph is raised all the way so it's hard to see the available movement. This works great for my rotary and flail mower as well as my drag blade.
/ Bush Hog flex link needed! #14
That style is often encountered;
It was designed to have the ears mount to the pin attaching the top link,
As in this photo, often times the top attachment hook has to be removed,
As shown here, usually pined into the clevis on the brush hog to allow lots of flexibility, while still lifting the brush hog when raised.
Atspower Mini Excavator (A60352)
Atspower Mini...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Caterpillar 966F Series 1 and 2 Wheel Loader Service Manuals (A63117)
Caterpillar 966F...
2016 Sky Jack SJ8831RT 31ft 4x4 Rough Terrain Scissor Lift (A61572)
2016 Sky Jack...
