Bush and bog harrow What exactly are and why ! Advise needed !
   / Bush and bog harrow What exactly are and why ! Advise needed ! #11
The ground here is pancake flat . and yes I want the fields back ! I will post pics soon . tnx for reply :)
Yeah that area is about as flat as you can get, good place to calibrate water levels.:D Always liked Denham Springs, many years ago my "Uncle Sam" Barron built a log cabin on his property and as a small kid I thought it was neat. It was really an outdoor kitchen. Sure miss the fishing and hunting in that part of the world.
When the ground is dry enough to work with I would suggest the larger mulcher heads on the skid steers. The small pieces left over will rot quickly in your area especially if you add some nitrogen fertilizer over it.
2018 Peterbilt 567 T/A Day Cab Truck Tractor (A60460)
2018 Peterbilt 567...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
Toyota RF1-SD1X45 4,500 LB Stand-On Electric Forklift (A59228)
Toyota RF1-SD1X45...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
