Burying plastic culvert pipe
/ Burying plastic culvert pipe #81
Dusty said:
Take your choice... the answer is both the same.
LBrown59 said:
Not the one across the front of my place .
I have a 15'' culvert and the ditch going into and out of it is 3or 4 feet wide and deep.
Either the ditch must be to big or the culvert is to small.
But which one?[/quote]
Are you saying That both the ditch and the culvert should be 15 inches ?
Or are you saying the culvert and the ditch should be 3 or 4 feet?
:confused:
/ Burying plastic culvert pipe #82
Dusty said:
The answer to the two part question you posed is:
A) Why do you need to drain water?
B) Large enough to carry all the water that will be going through the culvert.
C) Why would you forget the culvert?
D) Large enough to carry all the water that the ditch will accumulating.
A* So it won't flow over the wrong place.
B* What If I don't put in a culvert and just dig a ditch? What size ditch to dig?
C* May not need one.
D* That would be What?
/ Burying plastic culvert pipe #83
Don't you need a culvert to get across the ditch to your driveway?
/ Burying plastic culvert pipe #85
LBrown59 said:
No: this is not for the driveway
Personally, if you don't have a driveway going across the ditch, I would rather see it without the culvert.
A lot of people around here put a culvert in their ditch running the width of their property and then fill it over with dirt and plant grass over it. This defeats the purpose of having the ditch in the first place... then they complain about all of the water that runs off the road into their yard. :confused:
Now I'm interested to see how your ditch runs in front of your house.
Next time I'm over that way, I'll have to check it out! :)
/ Burying plastic culvert pipe #87
LBrown59 said:
Is there a road ditch running along the front of your property?
I believe that the road ditch in front of his property is stationary. :D
Absolutely not. My yard is downhill from the road. There is no room for a ditch because of a stonewall along my front yard.
/ Burying plastic culvert pipe #89
It would be hard to mow around if it was running! :D
How could you ever keep up with it?
/ Burying plastic culvert pipe #91
With your running lawnmower. :D
It would have to be with your moving running lawnmower. Just because it is running doesn't mean it is moving.
/ Burying plastic culvert pipe #94
1*A lot of people around here put a culvert in their ditch running the width of their property and then fill it over with dirt and plant grass over it. This defeats the purpose of having the ditch in the first place...
1* That's almost exactly what I did on the left side of my driveway last summer.
Buried a 110' of 15 inch culvert in a ditch that was 3 or 4 feet deep and wide and the state tells me I have to have an 8'' wide swale with a 6'' dip to the center. after installing the culvert.
Now that it's all done and I've had time to think about it the following questions come to mind.
1*Since a 15'' culvert was enough to do the job why was the ditch 3 or 4 feet deep and wide?
Only thing I can figure is a 15'' culvert must hold as much water as a 3 or 4 foot ditch *
2*Since all I need is a small swale to carry the run off what was the purpose in burying 1000 bucks of culvert in a 3 or 4 foot ditch that shouldn't have been there in the first place???
The Right side of my drive way has the same missed up ditch like I had on the left side.
I intend to correct that problem also but without making the mistake of blowing a 1000 bucks needlessly burrowing culvert.
LBrown59 said:
I think JimR had the running ditch not me!
My ditch only runs when it rains. It's lazy the rest of the time usually.
/ Burying plastic culvert pipe #100
LBrown59 said:
My ditch should be like this not a 3 or 4 foot one that has eroded away into an irregular gully across my front yard from one side to the other.
How do you plan to stop the erosion?
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
John Deere 2025R (A64126)
John Deere 2025R...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2012 FORD F-350 SUPER DUTY FLATBED TRUCK (A64276)
2012 FORD F-350...
