Burn pile maintenance
/ Burn pile maintenance #1
Anonymous Poster
Epic Contributor
Got a couple questions about how best to manage a burn pile (full of tree limbs, yard waste, scrap lumber, etc.).
1. What factors do you use on deciding when to burn off the pile? How important is wind? Recent rain? Amount of debris to burn?
2. My property runs next to corn fields. Do I need to worry about ashes starting a fire in the dry field -- even if the corn is down?
3. This is an old burn pile that has several feet of ash and soot that I'd like to remove. What's the best thing to do with that burnt material? Can it be used as compost or fertilizer or anything?
4. What other advice do you have?
/ Burn pile maintenance #2
Burned out...
1. Wind - biggest determinant!!! Too windy - no burn. Wet burn pile - lots of smoke. Personnally, I choose to make a small pile and have it awfully hot!! Somewhere between 6 - 10" across. Start small, build a good hot fire and you would be amazed at how fast it will burn. We typically have a brush pile somewhere near 15 -20 feet across and 5 or so feet high. Start early in the morning and it will be gone by suppertime.
2. I would wait until the farmer havests. Do you want to pay him for his crop loss? And other unimaginable problems.... If it has recently been havested wait awhile for the chaff to blow off. Be prepared to put out small fires, just in case. If it has recently rained, that is a good time to burn as it lessens the chances for brush fires.
3. Just get your FEL and spread it around. I wouldn't put it in your garden.
4. Check with your local fire department and government. They may have some rules in place. You may have restrictions on what you can and cannot do. My biggest constraint - always have someone around to watch the fire. I had to beg my wife to stay around a fire when I was at work. She had a couple of small incidents which woke her up. Usually flair ups when the wind kicked up and she built a really big fire. Watch the burning of leaves and paper as they tend to turn into burning missiles at the mercy of the wind and fire.
Terry
/ Burn pile maintenance #3
I'm also interested to hear any advice on this topic. I just made a huge pile this past weekend and here's my plan. The pile is a mix of spruce trees, saplings (mostly wild apple and wild cherry) and multiflora rose bushes. Most of this was cut early this past spring but I also added some more freshly pulled spruce. I'll use the rotary cutter in the next few weeks to clear the pasture of dead grasses. Sometime before the first snow I'll cover the pile with a plastic tarp and then wait till next Jan. or Feb. when there's lots of snow on the ground. Remove the tarp, light it up then get very long sticks for the weenie roast /w3tcompact/icons/smile.gif.
Dave
PS- I also made sure the pile is within reach of a long garden hose!
/ Burn pile maintenance #4
I wouldn't use the ash on a garden, it will increase the pH of the soil. Most vegetables like a slightly acidic soil. Grass, on the other hand likes a slightly basic soil. I spread ash out over the lawn.
Chris
/ Burn pile maintenance #5
In my area, in N. Calif...
Call the local BURN number. We can only burn on certian days, due to air quality, wind, fuel moisture. We are generally totally cut-off between May 15th through November. If it is a burn day, you still want to do it on a calm day. The wind can blow embers all over the place. Alway cut a wide fire-break around your pile, have a shovel and fire extinguisher available. If you can reach the pile with a hose, that is good too.
Keep in mind what you are burning. It is nice to get a real hot fire, 'cause it usaully burns faster and more complete. But, it can also have more sparks and brands which can carry a ways.
Here, legally, you can not have a pile larger than 4' across, and 4' high. You can only burn yard trimmings and trash. You can not burn construction debris, mattresses ect, legally.
If you are next to that corn field, wait till you have a good wetting rain. If you fire escapes onto another persons property, you are responsible for any damage it causes.
The best advice is to go check with your local Fire Dept. They will have all the info you need, and can direct you on the particulars for your area.
RobertN in Shingle Springs Calif
/ Burn pile maintenance #6
I think RobertN's advice to call your local fire department is the best advice. We normally have no burning restrictions except during dry spells in the summer, but that doesn't relieve you of responsibility if you let it get away from you. Around here, the volunteer fire department usually has someone available to bring a fire truck and stand by for "controlled burns" if you call them a few days in advance.
Other than that, I wait until not long after a rain, and start early in the morning on a calm day with dew on the ground.
Bird
/ Burn pile maintenance #7
Call the local fire marshall or the state ranger. NC has a ranger for every county as far as I know. The ranger for my county is within a mile or two of my land as the crow flies. I have talked with him a couple of times and gotten good information. I don't want him to HAVE to visit me! /w3tcompact/icons/smile.gif
NC requires burn permits at least in my area. The local farm supply places hand them out. Not a big deal. You can only burn yard waste/land clearing waste etc. Tires are a no no. Can't remember about construction materials but I would think that might be a no no as well. The ranger or marshal will know for sure.
My small material burns, 1-4 inch wood, but mainly 1-2 inch saplings, are stacked about 6 feet or so tall, maybe 10-12 feet wide and 12-15 feet deep. Give or take. I dug out a stump at the burn spot and then went in with the FEL and dug a pit maybe 5 feet across, FEL wide, and 6 or so feet long and maybe 2 feet deep. I place the burn material OVER the hole. The spoil dirt I have off to the side. I wait until we have had a decent amount of rain so the ground is wet. I have a pile of timber slash, pine bark, logs, and such near my burn pile so I'm very carefull with starting a fire. What I have noticed is that a decent rain makes the piles of slash very moist inside. I don't see how it would catch on fire but I still run around chasing embers.... /w3tcompact/icons/frown.gif
After a good couple of rains, and its cool/cold outside, and no wind in the forcast, I'll do a burn. I have had a pile ready to go for awhile now but its been to hot to burn. And this fire will be HOT! I get out first thing in the morning, put old newspaper in the pile and pour used oil on the wood/paper. Light a match and stand back! It will take awhile to catch but when it does I have had flames 10 feet or so in the air. /w3tcompact/icons/frown.gif
Starting the fire around daybreak is a good idea. It usually takes an hour or so after the sun comes up before any wind starts. I got caught one day with more wind that was forcast and that was not fun.... I've noticed that once a rain front comes through that we might not have any wind. So that is what I try to time. I have been lucky to have a rain on a Friday, burn on Saturday and have rain on Sunday/Monday! Thats perfect! /w3tcompact/icons/smile.gif
Once the burn is going, the first two hours are the worst when one worries about spreading fire. The ground around the fire is dirt so the fire can't spread that way so I worry about embers. Embers do travel a distance and are HOT. I picked one up to test once! /w3tcompact/icons/smile.gif Notice the word ONCE. /w3tcompact/icons/smile.gif After about 2 hours the embers seem to stop as the little wood has burned up and the big stuff starts to go. As the fire burns down I use the FEL to push stuff into a pile. Since I have this over a hole, the wood fall readily down and the heat is more concentrated. As I push the wood it just falls into the hole and burns easier. At the end of the day most of the wood is burned except for 10+ inch stuff. I take my spoil dirt and smoother the fire. I don't have water on the property so I have to use dirt. Works real well so far.
I keep the tractor nearby so if something does start I can jump on it with the tractor. For the first two hours I walk around the fire looking for embers.
In NC its against the law to leave a burn pile unattended. I see lots of people do it on large land clearing sites but I'm not doing it. I saw a burn two weeks ago that they started on a Monday and it was still burning on Saturday. I only saw someone pushing up the fire on Saturday. Never saw a soul the rest of the time and I made two trips that week....
Wind and a burning pile is a bad, Bad, BAD thing. The one time I had the burn going and the wind picked up I was a very unhappy camper for a couple of hours. The permit/laws also limit when you can start a fire.
Hope this helps.....
Dan McCarty
/ Burn pile maintenance #8
Don\'t use gas!
I forgot in the earlier post; DO NOT USE GAS TO START THE BURN PILE!
Use diesel if you have to, or charcoal lighter fluid.
Gas is just to volatile and dangerous
/ Burn pile maintenance #9
Re: Don\'t use gas!
Good advice about gas.
I sorta mentioned in my previous note that I put used oil on the pile to start the fire. I mix my old gas that I don't want to run in the chainsaw/blower/brush cutter in with the old oil. I have a watering can, /w3tcompact/icons/smile.gif, that I use to make my mixture and spread on the burn pile. It can take while to start burning especially as the pile is wet but that is ok.
The other thing I forgot to mention is how how the fire can get. I burn when during the winter and hopefully the temps are at least in the low 40s or cooler. During the burns I'm wearing very thick and heavy wool pants maybe with polypro long johns as well as heavy shirts. When I have to get near the fire with a shovel I'll put on gloves and heavy wool coat as well as my chainsaw helmet with the ear protection and wire mesh face guard. Even with all this I can't stand near the fire for very long at certain parts of the burn. I can run in move some wood about and then get out. The wire mesh on the face guard provides a suprising amount of protection from the heat.
When I use the FEL to push the burn pile I make sure I don't run over any embers..... /w3tcompact/icons/smile.gif
Later...
Dan McCarty
/ Burn pile maintenance #10
Re: Don\'t use gas!
Dan,
That made me think of something else, when you mentioned polypro skivvies...
When working around a fire, it is good to wear all natural fiber clothes, clear down to skivvies. This may be taking things to extreme, but those synthetic "plastic" type fibres can melt or burn when near high heat. I wouldn't expect a problem when you have heavy pants and wool jackets on, but it is a possibility.
Even with full turnout gear on, we do not wear synthetics into a fire; they can melt to your skin, even with all the safety gear we wear.
For anyone wearing a nylon jacket, or polypro "sweater/pullover",, that is a consideration. If a person gets to close while tending a fire, they will melt, and can stick right to your skin.
/ Burn pile maintenance #11
Re: Don\'t use gas!
Dang, RobertN, you are GOOD! LOL! /w3tcompact/icons/smile.gif
I was wondering when I wrote up my note if someone would get me about the Polypro. I normally wear either wool or cotton. Period. I'm sure I have some underwear and socks that are not natural but my shirts, pants, and jackets are wool or cotton. Its very hard to find wool long johns I did find some in the last year or so but its Polypro is easier to find.
You are absolutely correct about the plastic clothes. I hear that the Navy got away from polyester back in the 70's since they were having such horrible burn casualties due to the clothes. Some admirals wanted to stick with the old poly uniforms because the looked better but common sense prevailed. Or so I have heard.
I don't understand why law enforcement agencies still use the plastic clothes. The stuff is uncomfortable and dangerous. I guess it looks good...... /w3tcompact/icons/frown.gif
You don't want to wear your nice Goretex jacket near the burn pile! /w3tcompact/icons/smile.gif
Later...
Dan
/ Burn pile maintenance #12
In Kentucky you can only burn now from dusk to dawn and on non-windy days. I think you must actually have to be present when burning. I think you have to be at least 100' from any forest. Check local laws and use common sense.
The ashes, if it's wood it shouldn't hurt lawns or gardens if it's worked into the soil.
Bluegrass, Pick It Up!
/ Burn pile maintenance #13
Re: Don\'t use gas!
The last time I burned I had a pile about twenty feet in diameter and 8 feet high. I used about five gallons of watered gas I had to get rid of. I let it soak in for a while and then used a gallon of good gas to give it a little oomph and to run out a gas trail to light. I lit it and hauled ass so I was heading the wrong way to see it but my brother told me that when it blew it lifted the whole pile three feet into the air. Not really a good idea but I did get rid of the gas without dumping it on the ground.
/ Burn pile maintenance #14
Re: Don\'t use gas!
Whoa!!!!
I hope you don't do that to light your charcoal grill. /w3tcompact/icons/shocked.gif
But, I think a lot of us have had similar past experiences. /w3tcompact/icons/blush.gif
Terry
/ Burn pile maintenance #15
Re: Don\'t use gas!
As I have twice had the fire department bring out 6 trucks and a dozer to help quell my creations, I too have a method. /w3tcompact/icons/laugh.gif I'm not sure they like my methods though. /w3tcompact/icons/wink.gif
With a perfect fire, I hope to have rain day before or drizzle day of. I use kerosene in garden sprayer (pump type) so I can continue to "suggest" to the fire that it keeps burning until becoming self sustaining. I am in fact on first name basis now with my Forrestry dudes and they not only know where I live, they (sometimes) come out BEFORE I burn to be absolutely sure all is ok. In SPITE of this, I have still had a fire get way out of control (see above aforementioned 6 firetrucks & dozer). My smallest fire (after lumber dudes gone) has been roughly 30 feet diamater and (guessing) 12 feet +/- high. My LARGEST fire was probably 100 feet long, 40 feet wide and at peak, 20 feet high. Again, all numbers +/-
Joe (Forrester) had been out, cut fire breaks and I waited until rainy day to light. Was the most behaved fire I have ever seen (if you can accuse one of being "behaved")
I have also thrown one of those fireplace burning logs into a pile to start the fire. I acquired some and thought they would make a nice starter which they did.
Richard
/ Burn pile maintenance #16
I burn big brush piles while it's raining. If I can get a nice slow steady rain - perfect. Normally there's no wind with that and the rain keeps any hot ash that does go up from coming down hot. I use diesel to start it and it starts slow and burns at just about the right rate regardless of the material or size of the pile. The rain controls it for me - I don't have a source of water nearby so I let mother nature provide. I also like to let a pile "mature" for a year or two before I burn it. It's a lot smaller and compact then.
mike
/ Burn pile maintenance #17
Re: Don\'t use gas!
Gas is BAD stuff. My brother is now 54 but he almost didn't make 12. He was burning trash in a barrell (thats what we did back then). He had poured the gas out of a gallon jug and backed away form the barrell, then lit it. Somehow the fumes had gotten into his pants leg and he caught on fire. After several months in the hospital and several skin grafts, he survived. He has huge scars that take up his entire legs and stomach area (where they grafted skin). So an empty gas can is even more dangerous because of its explosiveness.
I was only 4 at the time so I don't remember it.....
Alan L., TX
/ Burn pile maintenance #18
Re: Don\'t use gas!
Gas, kerosine, diesel? Jeez, guess I'm more patient. I have 2-3 or more fires a year of mess we accumulate from fighting Mother Nature. We've always started the fire with several [4-6] wads of newspaper stuffed into strategic places around the perimeter. We never burn on windy days, & not unless we've had rain in the last week or so. Never had a problem getting a good burn.
/ Burn pile maintenance #19
In Pennsylvania, where I've got my country place, we always wait until we've got snow on the ground before we do any burning. In our neck of the woods we get those nasty combinations of rain, freezing rain, and snow... so during this time of year, the underbursh and fallen leaves are wet / frozen and covered with snow.... no way there going to burn! We also wait to consolidate the piles of brush or junk or what ever we've gotta burn until winter to eliminate the critter factor... you don't have to worry about snakes and spiders when it's only 20 degrees outside!
We also call the fire department, just to make sure there isn't a burn ban, but mostly as a curtoursey call ... the neighbors will likely see the smoke and call the fire department anyway!
/ Burn pile maintenance #20
<font color=blue>wait until we've got snow on the ground</font color=blue>
Excellent idea, but of course, if I waited for snow, my grandkids might not even get to burn it./w3tcompact/icons/laugh.gif However, about 1/6" of rain yesterday, 52 degrees this morning, very heavy dew, thick fog (visibility less than 400'), so my little pile of brush and the old oil from the last oil change went up in smoke this morning.
Bird
2011 PREMIER PUMP AND POWER 3HC-DM16 TOWABLE DIESEL PUMP UNIT (A67714)
2011 PREMIER PUMP...
2015 GMC SIERRA 3500HD CC (A67714)
2015 GMC SIERRA...
Sullair 375 CFM Mobile Air Compressor (A68134)
Sullair 375 CFM...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2018 Ford Explorer AWD SUV. (A66738)
2018 Ford Explorer...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
