Bummed Beaver
/ Bummed Beaver #1
arrowhead6771
I need some advice guys ..a few weeks ago i picked a beaver in real nice shape..Planning on using it to mow on tree farm.well I was reading about beaver's pto running counterclockwise my heart sank.I ran out to barn fired it up and checked and sure enough i never took notice or doubt i would have bought it ..I have a brush i was going to use think i could flop the blade around and would it work or will i need to buy a new tractor any help would be greatly appreciated ..i love the tractor i have been pulling trees with it and works great no other complaints but this is a big one...why would they make pto spin like that ???well thanks for your time...
/ Bummed Beaver #2
WoW, You learn something new every day.
As for fliping your blade around it sounds logical,But i really could'nt tell ya./w3tcompact/icons/hmm.gif
/ Bummed Beaver #3
There were some early Kubota's that did the same counter-reveloution thing with the PTO shaft. My neighbor had one. There were a bunch of immplements made especially for that situation back then.
You might be able to find a brush hog that will operate in both directions, but I would think that you may have a problem with bolts loosening up because of the reverse rotation. A dealer would know for sure.
The other thing is if they made the rotation opposite they must have made immplements to go with it, they might be harder to find and a little more expensive.
Randy
/ Bummed Beaver #4
You also may have a problem with the gear box on your brush hog running backwards. Also the PTO shaft is a fine spline and smaller than normal PTO, does yours match? I know Woods makes a finish mower for this use... think it is an RM 48. Good Luck
/ Bummed Beaver #5
Would it be possible to add a gear box to the PTO that will reverse the rotation? Could go on the tractor or on the implement.
Egon
/ Bummed Beaver #6
My old Woods brush hog, and I think some still today, use a huge (~1-1/2") pin instead of bolts to retain the blades, so I don't think anything would come loose if you used one of these. However, in flipping the blades, you will lose some of the "lift" effect, the blade shape provides when spinning. You could just regrind the blades to reverse this. If I could find a used hog, I'd certainly give it a try.
/ Bummed Beaver #7
There was a reverser made for these tractors, my parts manual shows the breakdown for it. It also converts to standard PTO output shaft. No luck finding one. If you would happen to mfg. one, keep me informed I would be interested.
/ Bummed Beaver
I came up with idea last night to build a gearbox which will convert me from 22 mm fine spline to 1/38 6 spline and changes direction to cw.I have a buddy that is a machinist called him and he dropped by this evening he just happens to have lots of gearbox experience like this he looked at it and said no big deal to build so..I need to gather some parts and hopefully in a few weeks I will have a clockwise beaver..thanks for all the feedback I will post pics and tell how it hopefully works in a few weeks
/ Bummed Beaver #9
Sounds like the start of a new enterprise. You could call the business the "Beaver Retrievers". :eek:)
/ Bummed Beaver
Oh as far as the brushgog I figure the bolts are right hand thread and probably would come loose also that I still could not use a pile of other attachments like my sprayer and hydraulic pump etc. etc. so is a must to go clockwise..here is a pic of me and el beaver' hahaha damm old lady always taking pictures hahhaha
/ Bummed Beaver #11
I have a Beaver which has an optional gear box with a standard size PTO to change the rotation to Clock Wise. Evidently, they came with the smaller splined PTO when new. Your best option would be to try to find a gear box to make the change, but they probably are very scarce. Good luck with this!
Thom
/ Bummed Beaver #12
Think of this... Most all of the brush hog gear boxes are (I wasn't paying attention is it right turn?) so the teeth on the gears are worn on one side only. If you find a used one and reverse the blades or fabricate your own new blades to work backwards on it you'll have brand new surface on your gears. It'll be a brand new mower at a 10 year old price. Am I right?
/ Bummed Beaver #13
I have a woods rm 48 with the small pto shaft for a beaver and its setup to run counter clockwise. if you can use a finish mower and are close to pittsburgh pa make me an offer. It works fine, could use some TLC but Ive used it the past 2 seasons.
Jim
stripercity@live.com
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
