built pallet forks
   / built pallet forks #11
Nice work. ONe thing I don't understand for those of you with forks that sit on a notched bar like that, is what keeps one from bumping up off the notch?
Jim
   / built pallet forks #13
forks were given to me, i made the everything else, 5 inch c channel is a little over kill but that was free also, all done with torch and a mig, well ran out of wire, had to stick the top cage, next is a cultipacker, and FEL boom, thanks for the replys I dont know how to load photos on top of each other I thought I did..
Not a problem. It's good to excercise the horizontal scroll bar once in a while anyway. LOL
Jim
oh the bottom of the forks have a reverse hook, if you look at the first pic the forks have to slide on first, right now i cannot take the forks off without cutting off the side rail
   / built pallet forks #15
"on the bottom of the forks have a reverse hook, if you look at the first pic the forks have to slide on first, right now i cannot take the forks off without cutting off the side rail"
Frontier forks are designed the same way. However, they have a "notch" cut into the bottom flange, right in the middle, that is just wide enough to allow the fork to be tilted up and removed from the frame.
good idea if I wanted to use the same quick attatch plate for a fel boom:confused:
   / built pallet forks #17
"good idea if I wanted to use the same quick attatch plate for a fel boom"
I like the way you're thinking. You could make a whole series of attachments to go on the fork mount. Boom pole, receiver hitch, etc.
   / built pallet forks #19
I think if you edit your original post and then put a carriage return (hit enter) between each of your picture files then they will stack properly.
Don't do image1image2image3
Try
   / built pallet forks #20
Ya, mine was a little sticky at first, hadn't used it in a while either!
I love my forks; good build - you will not be able to do without them once you have worked with them.
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
