Building A small pull pan Type scraper
/ Building A small pull pan Type scraper
OK 5 4 3 2 1 ignition on boosters! We have lift off! NOT! Hey guys this aint rocket science we just need to move a little dirt here and there. Now I never planned it so that this thing get every last cc of dirt and every last once of HP out of any tractor. This scraper has a wide range of power consumption from about 20 to 40 HP now that is a w-i-d-e range of power. I am just talking of reviveing a 60 year old design from the grave. It works well and I belive is quite up to date still, maybe could use some fine tuning of the old one way (rise up fall down) hyds but that is about it. Its all there just need builders/users. Self loading, low power requirments, spot dumping, self leveling, short turning radius, quite easy fabrication using only farm shop tools standard of the shelf parts. What more could a user/builder ask for in a small scraper?? You tell me!
Thanks EF
Renze said:
Let's say that the lower drawbar is mounted 50 cm behind the rear axle, and 50 cm below the rear axle. The scraper holds 7 ton of dirt of which 2 is on the drawbar. The draft requirement equals the kerb weight of the empty tractor, which is 3,5 ton, of which 2 ton is on the rear axle and 1,5 is on the front axle. The axle heart distance is 2 meter (it's 2,14 meter on my 5245 but 2 meter is easier in this math.)
These are just estimations, close enough to real life scraping to get the general idea.
In the static situation, there is 2 ton at 50 cm behind the rear axle. That's 1ton/meter. At 2 meters from this point (the front axle) this will be 0,5 ton negative front axle load. 1000 kg will remain on the front axle.
This means roughly 4000 kg on the rear axle and 1000 on the front axle.
When the tractor pulls, there are two main points of force: the center of the rear axle, and the center of the drawbar eye. The tractor pulls with a force of 3,5 ton on this tow eye, and the corresponding lever is 50 cm, which causes a momentum of 1,75 ton/meter.
The result 2 meters further up front on the front axle, is 0,875 ton. The front axle load will be the 1000 kg, the outcome of the static calculation (at standstill) plus the dynamic force caused by the pull itself. this is 1000 kg plus 875 kg is 1875 kg on the front axle, and 4000 kg on the rear axle.
The static load index of the 5245 is 1800 kg up front and 3600 kg rear. That is the load to be bouncing on the road at 35km/h. At slow speeds (front loaders) the operators manual mentions a max. dynamic load at speeds below 10 km/h, of 2,5 times the static load rating. The tractor will do just fine, i just dont want to load my front axle that high because the bearing capacity is with front loader use in mind, not with heavy draft applications.
Off course there are loads of variables that have stood out of this calculation, like the reaction force of the wheel torque of the rear axle on the tractor body, which unloads the front axle, reaction forces in the front wheels etcetera. I hope you get the general idea, which is that any drawbar which is mounted higher or lower than the rear axle, causes a reaction force when the tractor starts to pull on this drawbar.
/ Building A small pull pan Type scraper #83
Earthface the rough calculations were to back my own plans, not yours... ;)
Actually i'm thinking that my next project will be a straw bale chopper/bedder instead of a scraper... Maybe i'll hook up the 2 meter wide 3pt hitch bucket onto a dolly frame to use as a scraper, its cheaper and with a front gate, i would be able to hold 3 yards as well. A scraper is more fun, but a straw blower just has more use for me..
Heck I knew that, I just had to rib you a little as all that mech dynamics is WAY over my head, and most of the rest of the guys here too. It was just getting WAY to serious for a good BS session ;))
Iam using this scraper just now and having just to much fun playing in the big sand box to make the Drawing just now. But when the ground turns to a glacier I plan to draw it out. I havent got any Idea of price yet it is going to be plenty of work and I know that it cant be done for the $20 bucks that had been sugested earlier. There seems to be some demand for them but I bet it will be small. Will advise when done;))
Thank you for your input and interest
EF
MikeD74T said:
earthface, Are you going to offer plans? How much? Mike
/ Building A small pull pan Type scraper #86
Owned a 1.5 cu yrd scoop 2 wheels, hyd lift,rope operated dump,
pulled it with a D46U or a 60HP Inter(564)(weight aprox 7500lbs)
wheel tractor.
From experience and conversation with other owners,It is my opinion
that at least 40HP per cu yrd is needed to handle these machines.
Providing you could rip the ground properly, when it became too hard
for the scoop to dig and kept at it, a lot of dirt could be moved.
The rope dump set up was utilised as most tractors only had one
hydraulic outlet in those years.
R W
/ Building A small pull pan Type scraper #87
That'd be a "Tumblebug"..doesn't need hydraulics.Just pull the rope or lever and it rolls foreward to dump! /forums/images/graemlins/grin.gif
Am trying to find out the make of my dads old tumblebug.
It is 42 inches wide,has a rope lever,a lever on hitch to level scraper while
moving to dump area.
Was yellow in color.
/ Building A small pull pan Type scraper #88
I was wondering if anything ever came of this project?
I'd love to built a small pan for a 40-60 HP tractor.
Anything better than a pool scoop or toting dirt in the front bucket has to be an improvement, so I'm not looking for anything huge or too fancy or expensive.
Jim
/ Building A small pull pan Type scraper #89
I ran into this after reading about R.G. LeTourneau and then finding a video of an Ashland scraper that looks identical to the OP. If anyone made something of this let me know.
/ Building A small pull pan Type scraper #90
Did you know that the last post to this thread was several years ago.
/ Building A small pull pan Type scraper #91
Could you give more details as to what you would like to know.
/ Building A small pull pan Type scraper #92
Yes. Yes I did.
As unpleasant place as the Internet can be, places and BBS of this nature are a great repository of vast knowledge. It is like having our Grandfather back. Sometimes we have to remember that today's "hobby" compact tractors exceed the power, control, speed, reliability and sometimes even the brute force of the top of the line construction equipment of a century before. All to often it is our knowledge and the methods we use that are our limiting factor.
The success of the OP design is evident, and desirable. Maybe our community has not lost these people and their experience? Unfortunately the information they possessed did not remain with the conversation.
I have a 3 yard dump wagon. A small scraper that will unload spreading its load while having the advantage of a low sidewall for easy loading via a backhoe is not something you see at every "gentleman tractor" dealership.
/ Building A small pull pan Type scraper #93
I would like to know what materials, geometry of the apron, blade, linkages and frame.
Today we make a few calls and high quality steel is cut with precision that is unimaginable to the men that built the machines that this nation. The average ac buzz box has welding capacity superior to most manufacturing before WWII.
This could be a nice project. Yes A LOT of welding! But an Ashland 25 is $7k
/ Building A small pull pan Type scraper #94
The Ashland25 appears to be a well designed piece of equipment.
To build a similar type of machine you may have to find one to copy from, to get the geometry right, as with this set up there would not be a lot of room for error.
I have a brochure on another make that has the size of the steel used in the construction of the bowl, will send when I find it.
It will be a good project, you will be pleased with it when completed, although it will take time you will have saved a good amount of $s.
Found the brochure.
1/4" base, sides & apron. (would be inclined to use 5/16"for the base).
5x3x1/4" RHS for frame.
/ Building A small pull pan Type scraper #97
Yes. Yes I did.
Nicely stated. The information in these threads is, and will remain, relevant for many, many years.
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
43024 (A59228)
43024 (A59228)
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
