Building A small pull pan Type scraper
/ Building A small pull pan Type scraper #41
Problem with those V levellers is that i cant push dirt into the dead furrow close to the fence, after i have ploughed a horse pasture. They work great to maintain small dirt roads on farms, to fill the wheel ruts. Except for that, they arent used very much in Holland.
I've looked at the durabilt scraper, and it looks like a very nice design, simple and easy. I still question myself if it wouldnt be easier to have a fixed blade scraper with a pivot point behind the blade, to make the blade depth indifferent to the pan dump movement.
http://www.agequipmentusa.com/agequipmentusa/PDF_files/Durabilt%20Dirt%20Pan.pdf
/ Building A small pull pan Type scraper #42
Renze Ive used an 18 yard Reynolds fixed blade pan. They arent as heavy duty as the others But then again im not a fan of the large pulltypes either. It does make dumping on grade a bit easier becacuse the blades stayes where its at through the whole cycle and ou dont have to raise it. The paddle wheel at work the bowl slides back and the plate comes forward. In a perfect world with out wear this is the same thing as a fixed blade but not on our machine. Thats why I like a forced ejection scraper its the same principle as a fixed blade. But again a dump type ejector is simpler to build. On alot of jobs with tractor pans youll see all the front pans be movable dump bowls with the trailing pans havin a fixed blade to mop up.
/ Building A small pull pan Type scraper #43
/ Building A small pull pan Type scraper #44
tractortaylornut, i cant see where you're going, did you try to say that a pivot dump scraper has more wear than an ejector ?
I like this Miskin scraper: http://www.miskin.com/D-features/tipeject.htm
BTW has anyone seen the Miskin air assisted scraper ? it makes the dirt boil up in the bucket by loosening it by shooting a blast of air through the dirt through openings in the blade. They get full loads with a half size smaller tractor than without air assist..
http://www.miskin.com/AirScraper.htm
/ Building A small pull pan Type scraper #45
/ Building A small pull pan Type scraper #46
Renze I probably went on rambling again lol. What I meant is a fixed cutting edge scraper hasnt got the resilience of a dump bowl scraper and a dump bowl has a few draw backs to an ejector type. The fixed edged can break at the mouldboard in if it encounters an imovable object. I used to have a 20 inch diameter hydraulic ram that was 2 feet long to straightn the bowls and moldboards on pull type scrapers. We've seen some the bowls get pulled down or warped so bad that the pins they pivot on would come out of the scraper frame. That only happens when you find things like large pilings in the ground Most tractor pans load using momentum rather than pure grunt. So when you strike an object sometimes alot of damage can occur. I mainly run a paddle wheel scraper finishing or and ejector when i have to run a scraper but over the last few years ive logged alot of time with a tractor and pan combination. They both have advantages and disadvantages to. Ive actuall seen and air scraper work it was neat watching it but the man that bought his said somtimes mainenance was a night mare with the compressor.
/ Building A small pull pan Type scraper #47
/ Building A small pull pan Type scraper #48
O.K. I see your point now: I already had my thoughts on how to make the blade as thin as possible to keep the traction requirement low, yet strong enough to take an impact of a tree stub or piece of rock, without disaligning the big hinge, which is as wide as the bucket. with a 3 meter long pivot pin it takes just a little deformation to jam it.
Anyways an ejector scraper is too expensive to build and a simple dump bowl has very little use in the Dutch land levelling business. Next to that, in our rock free soil the collison damage risk is very low, and our 50 and 70 hp tractors will just stop and dig in with a 5 yard pan if it hits something...
/ Building A small pull pan Type scraper #49
/ Building A small pull pan Type scraper #50
Earthface I am interested in your scraper plans both sets. Please email.
alabamaed
esheltonatmon-cre.net
/ Building A small pull pan Type scraper #51
alabamaed
/ Building A small pull pan Type scraper #54
Thank you, hans, that is a great looking little scraper. I've heard of Overland, but don't see them.
Looks like a nice little dirt-moving combo.... /forums/images/graemlins/smile.gif
/ Building A small pull pan Type scraper #55
/ Building A small pull pan Type scraper #56
Hmm, a one yard bucket... it is a beautiful toy to use with the little Fergie, but my 3pt hitch earth bucket is just as big...
Hey wait, i have a 1965 Zetor 2011 two cylinder to hook up to that Overland scraper !!! /forums/images/graemlins/blush.gif
/ Building A small pull pan Type scraper #57
/ Building A small pull pan Type scraper #58
I just ran across this ad for one for sale, in case anyone is interested;
Soilmover brand pan for sale, $3000 in MN
Boy aint that a cutie!! I wonder if he can fill it using that ATV?
If it does in good dirt they may be able to move 40 or more yds a day. Wouldnt that be wild to build rds and level acres and when the neighbors how you pointed to the atv!!
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
Hydraulic Breaker Skid Steer Attachment (A66734)
Hydraulic Breaker...
2017 International WorkStar 7500 T/A VacCon VPD4211 Combination Sewer Jetter Vacuum Truck (A66736)
2017 International...
2011 UNKNOWN FRAC PUMP (A67714)
2011 UNKNOWN FRAC...
