Building a Garage Pit
/ Building a Garage Pit #81
OrangeB2400,
I have a pit, love it. Suggestions- 4' is too wide. Mine is 3' and works fine. Mine is 6' deep-too deep and I am 6'. I think about 5'2"-5'4" will be about right for me. The pit is a total of 18' long, with steps at one end. I work on both small cars and a F250 4x4. Mine is filled concrete block, with a 3"x3" angle iron track on top, with the poured concrete floor level with the top of the angle. The angle down both sides gives me a ledge to put the cover. The cover is two 1"x6" oak boards, rough cut, with 3/4"plywood sandwiched and bolted together. I just remove as many as I need to get to what I need to work on. The cover stays on except when a car is over the pit. It is strong enough to drive the front wheel of a Dodge 3500/Cummins down the middle. Bowed a little, boys probably won't do that again. The garage/shop is mine/private/farm so not many people around.
I might have the height for a lift, but like you, I could build a pit. after 10+ years, only thing I would/will change is the depth.
Almost 10 years since I posted this. I still think my recommendations on size is good, but I just don't use it enough. I use ramps to change the oil, haven't used the pit is 4+years. My wooden cover is no longer safe, too much moisture, so I will be filling it in sometime over the winter. I doubt I will get a lift, getting too old to do the heavy stuff like transmissions, clutches and engine replacement.
/ Building a Garage Pit #82
After 28 years of use, I am still really glad I did not build my pit too deep. 3' depth allows me to work sitting on a stool or kneeling on a scrap of carpet. I also can store my 5-gallon direct-fill oil change buckets in there.
2013 GMC (A62613)
2013 GMC (A62613)
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
Bobcat T650 (A64126)
Cub Cadet MOWER (A64557)
Cub Cadet MOWER...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2018 Kubota U35-4 (A64126)
2018 Kubota U35-4...
