Building a bridge?
   / Building a bridge? #41
I paid $750 (including 7% taxes) last spring for my 4' dual wall plastic culvert 20 foot long
It will be there long after you're done needing it. :thumbsup:
   / Building a bridge? #42
I hope not, it is still a hundred feet away from what I hope to be its final resting place, I had a heath issue after I brought it home and got it unloaded and moved close to the stream.
Then it was much to wet all season to get it installed by myself.
I thought about hiring it done, but that is not nearly as much fun
   / Building a bridge? #43
   / Building a bridge? #44
LOL, as I did
:laughing:
Actually I sort of hoped he was being facetious
   / Building a bridge? #45
LOL, as I did
:laughing:
Yep, Radios 1 is deadpanning us. Unless that watershed has changed, the only hope is no more gullywashers. Good luck with that...
The area is generally Sandy. I may first try taking the bank down then putting some large gravel in the flow area. This area doesn't generally flood and the flow is fairly consistent.
   / Building a bridge? #47
I saw in the beginning of this thread several comments were made about using a semi trailer which is a little over kill for a 5-6 foot gap. My neighbor had me bring home a flat bed from a straight truck. I was 20 feet long and was light enough to move around with a skid steer. And it was strong enough to hold up the SS.
   / Building a bridge? #48
We have multiple creeks just like yours .on one i use 2 24 in culverts and in normal yrs i may have to repair the crossing once or twice a yr, the other crossing is way to wide so we just cut down the sides, when the weather is dry its no problem crossing , this time of yr foget it.
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
2017 Polaris 500 Ranger Diesel (A50324)
2017 Polaris 500...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
