I removed mine when I installed the QA, and found nothing that wasn't obvious. You take out the small bolts that cross pin the pivot pins in place, and knock them out. Just make sure you have the bucket setting pretty level when you do that. Don't tap on the grease fitting end, and make sure the pins go back in the way they came out. I did find that some pins fit some holes better than others because of paint, and minor missalignments.
