Bucket pins/bushing issue
/ Bucket pins/bushing issue
Picked up the pins and accompaning hardware.
Banged the old ones out, no problem.
Got the first one banged in, easy-peasy.
Got the second one 2/3's of the way through...and it hangs up. Can't get the last bit of loader hole to totally line up with the bucket hole. Just a teeniest tiniest bit of an overlap...and the pin won't slide through that last inch. Its the bucket that needs to come back towards the arm by a smidge. I can lever the bucket AWAY from the loader arm...but I can't move it CLOSER to the loader arm. No matter which way I start the pin, it always hangs up in the last bit. It's like there's a tiny twist.
Is this just a matter of fiddle, fiddle, fiddle until she slides through...or should I unpin both of them and see if it'll line up better? I mean it's just the last 3/4s of an inch.
/ Bucket pins/bushing issue #22
Take the first pin back out, then see if the other pin will go in. If it does then try putting the first pin back in.
/ Bucket pins/bushing issue #24
Those readers will surely work.
Other suggestions: grind a v edge on the end of the pin. It may make it easier to start.
Move the bucket up & down and curl. Try different positions and you may get a spot that works.
A bolt same size as pin with a v ground on one side or around the circumference and drive it in from the other side. Then try the real pin from the original side.
Any combination of bucket movement and tries may work. Even try a light push or back drag may help.
/ Bucket pins/bushing issue #25
I wonder if that undersized pin on the opposite side allowed enough bucket deflection to bend the (now) misaligned side? With the bucket off the loader, a length of pin diameter bar stock longer than the overall width across the loader arms would let you guage if the two loader holes are coaxial, and the four bucket holes coaxial as well. That may affect how you want to fix it.
Well, I went out this morning and fiddled more and more. It was just hanging up by a millimeter - and for love nor money, it would not line up easily. So I got it as close as I could...and then gave it about three or four whacks with an 8-pound sledge. It slid through. Of course the holes for the 2 inch retaining screw aren't lined up...but I don't think that sucker's gonna slide out anytime soon. So I gave it a shot or two with tha grease gun, and will keep my eye on it in case it ystarts to back out.
Thanks for the replies, guys - and helping a rookie out.
PS - i was in the dealership so long, gushing over a new 3301 with a backhoe that my wife started texting me from inside the car. I said I'd only be a second, right. I figure that's not even close to making up for all the times we've run into Costco "for just a few things"
/ Bucket pins/bushing issue #28
If you roll the bucket down, it should eventually line up, then you can pin it in. It needs to be pinned so the pin spins where it goes through the loader arms, otherwise, it will chew out the bushings welded into the bucket mounting brackets.
Aaron Z
Aaron Z
I'll take it out in the next while and dump the bucket a few times to get the pin properly seated in there and maybe loosened up a bit. Then I'll see if I can tap it ahead, line up the holes and get that quarter-inch retaining bolt in there. But its a bit cold to work outside...so tomorrow is another day.
Well, I went out there and got it done....but mind you, that pin is in there TIGHT. You have to to bang the holy **** (jeez, you can't say aitch-ee-double-ell here?) out of it to get that pin to move either way. I managed to get that 1/4 x 2 inch retaining bolt in there - again, using the BFH method. I've loaded it up with grease and the bucket dumps OK without squealing or hanging up. My question is...Will it be OK longterm that the one pin had to be HAMMERED in that last inch? Is it occasionally normal that one has to resort to the sledge to persuade the odd thing?
/ Bucket pins/bushing issue #31
Oh sure, a bit of usage and those pins will adjust themselves to a perfect fit.
Think of it like lapping valves.
Main thing is that they don't bind and snap so keep well lubed.
/ Bucket pins/bushing issue #32
This^
I would guess that either something probbaly got bent/tweaked at some point, or it got a little dirt in with the grease. Did you clean the hole out first to make sure you didn't have any dirt/old grease mixed in?
Aaron Z
This^
Aaron Z
Oh, for sure. That would have been TOO easy, right? Nope, it was just a misalignment of a millimetre or so between the loader arm and the holes on one of the bucket holes. I could just feel a little lip with my finger. It went in 2/3s of the way, and then got hung up. Might have gotten racked a smidge out out of alignment at one point. Anyways, she's in now and I'll check on it periodically.
/ Bucket pins/bushing issue #34
Perhaps that happened when the pin that was replaced with an undersized pin was lost?
Aaron Z
/ Bucket pins/bushing issue #35
You won't have an issue with the pins. Most of mine have had the BFH used on them at one time or another.
/ Bucket pins/bushing issue #37
Actually, no. That side was easy-peasy. Went in like butter. The other side was the issue.
What I mean is that perhaps this side got bent when the pin was lost on the other side (if the missing pin wasn't noticed right away).
Aaron Z
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
AGRIC AFMJ65 - 65" ROTARY TILLER (A64277)
AGRIC AFMJ65 - 65"...
2021 CAT 299D3xe Skid Steer w/ 2021 CAT HN415c Mulching Head (A62613)
2021 CAT 299D3xe...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
Farm Hand Silage Wagon (A65640)
Farm Hand Silage...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
