Forks Bucket Forks
/ Bucket Forks #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
I need some bucket forks, but the ones I want require 3 big hooks to be welded on the top of the bucket. The forks each are "L" shaped with a piece coming down across the front of the bucket from a horizonal bar attached to the 3 hooks, then down below the front lip of the bucket they turn 90 degrees out from the bucket.
I understand you can put these on and take them off without leaving the seat of the tractor. Thats why I'd like to have this kind.
I have found some that have a couple of tons of payload, but my B 2710 only has a capacity of 900 some odd pounds on the FEL, so slightly over that should be all I need. The heavy duty ones are around $1,000, and I sure as heck don't want to pay near that for them.
I see some on Gearmore's website that have 1000# capacity, stick out 32" I think, but they don't post a price.
Does anyone have some of these, or know what the price is?
/ Bucket Forks #2
/ Bucket Forks #3
Alan,
Let me suggest you do a search for "forks" or look at my posts and check the one "...show me your forks now let me show you mine"
There are several threads already here re: forks.
I'll be happy to answer any questions you have about my forks.
They are working great. Haul a BIG pile of limbs, dig up small bushes, break limbs off trees/w3tcompact/icons/smile.gif, skin up side of shop/w3tcompact/icons/grin.gif, any number of things.
/ Bucket Forks #4
Alan,
Here is a picture of the Gearmore 2500lb model (one size up from what you are looking for). They are well build. They attach and detach in seconds without leaving the seat. They work great. The only downside is when you try to dump the load, the forks swing out away from the bucket. I mostly use mine on palletized materials and they work great. I think the cost was $300 with the hooks welded on the bucket.
/ Bucket Forks #5
With the picture this time.
/ Bucket Forks
Thanks RMulkey, those are the ones. I hate to hear they swing out from the bucket though. That might make it hard to dump stuff out of them. I wonder if they could be secured at the bottome somehow to keep that from happening.
/ Bucket Forks #7
From the tractor seat, how do you see the tips of the forks to line them up with the notches in a pallet?
Mine hook on in place of the bucket, and even then they are sometimes hard to see from the tractor seat.
/ Bucket Forks
Thanks for those links Bubenberg. I had seen the Arrow Parts site and never could find any prices on there. The clamp on forks would seem to be OK, but those Gearmore L shaped ones seem much easier to put on and take off. I might have to consider the clamp-on, because the ones I had wanted apparently aren't rigid against the bucket. As for the forks that mount with the chains - anyone who has messed with those chain binders know what a ***** they can be. I really don't want to have to mess with putting those on.
Those with the the ones I'm talking about - that mount using the 3 weld on hooks - are they hard to dump, or does gravity take care of the problem?
/ Bucket Forks #9
You can defenitely secure the fork to stop them from swinging when dumping,use a long chain w/a binder and go around the forks and the back of the bucket and tighten down w/the binder,just make sure you don't run the chain through any of the linkage for the bucket or it may get pinched or restrict the rotation of the bucket.
/ Bucket Forks #10
your assessment is correct ...gravity does it's thing
/ Bucket Forks #11
/ Bucket Forks
gotrocks - did you build those? Looks like a very good design.
/ Bucket Forks #13
Alan, go to this address and it should show my original description.
http://www.tractorbynet.com/cgi-bin/compact/show...80931
I had a friend give me the actual forks from a fork lift truck.
Got a couple of pieces of 2x4 thick wall hollow tube and a couple of other flat pieces and an old discarded round shaft. Would like too have had a little larger diamiter but this works. I have cut 2x4 treated pine as stakes to extend the top of the forks. I tip the bucket forward ease up to the forks and roll the bucket back and they are on. I have since added a tooth bar and the forks still work fine. Just holler if you want more info.
/ Bucket Forks #14
It happened again, tried to edit my post and all bytes stopped going or coming. The address was not complete.
Let's see if it's all there with this:
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=implement&Number=80931&Search=true&Forum=All_Forums&Words=gotrocks&Match=Username&Searchpage=2&Limit=25&Old=allposts&Main=80931>You showed me your forks now let me show you mine</A>
That looks more like it.
Well it does run off the screen but I forgot how to fix that.
/ Bucket Forks
Thanks gotrocks, I went back to the original post and looked at the forks. You should put those on the market. Unfortunately I don't own a welder and its been 30 years since I used a welder. I was in high school ag.
/ Bucket Forks
Well, my dealer called Gearmore about their smallest quick attach bucket forks (1200#) and its $700 with the hooks welded on the bucket. WOW!
I guess I need to go with one of the clamp on varieties. I like the looks of the ones Harv has. Is the side to side movement a problem? Also, seems these are Gearmore you have. You said you paid $350 I think - wonder how much more they would be here in Texas.
/ Bucket Forks #17
<font color=blue>Is the side to side movement a problem?</font color=blue>
Only when you put lateral stress on them with the tractor -- like when you make a turn too close to a tree (don't ask how I know
). In other words, they won't move side to side under normal circumstances, doing normal forklift stuff.
<font color=blue>You said you paid $350 I think</font color=blue>
Yup.
<font color=blue>wonder how much more they would be here in Texas</font color=blue>
I wonder, too. Although based in California, Gearmore does have distributors around the country, so I guess it all depends how close you are to one of them.
Also, there are other brands out there, even though I can't tell you what they are at the moment. Carver Equipment used to carry some, but I can't find them on their current web site. Might be worth an email.
/ Bucket Forks
I got a price of around $300 for the #1500 quick attach forks from www.arrowforklift.com, but the shipping is probably considerable. These are the ones, you recall, that have 3 mounting brackets that have to be welded on the bucket, and a shaft fits in the 3 hooks and the forkes are L shaped.
I just thought of one other issue. I will need to use these forks at other locations (my Mother's property) which means I will have to trailer the 2710. The quick attach forks appear too large to fit on the trailer with the tractor, and if mounted on the bucket would probably hit the towing vehicle. Maybe I could point them in the air?
Whereas the clamp-on, while a bit heavy, could be laid on the trailer with the tractor and mounted when I get there. Plus, based on what Harv is telling me, the side to side movement is probably not a problem. Really the difference is the increased vertical length on the quick attach, and the ability to mount/unmount from the tractor seat. The clamp-ons don't appear that difficult to install either, so thats probalby not a big factor. Plus the clamp-ons would appear to be more portable, and don't require welding on the bucket.
Those with the quick attach, has there been a problem with trailering?
Thanks for all the help guys.
/ Bucket Forks #19
Just my two cents but I would go for the ones Harv has for the following reasons:
1. 1500 lb capacity is kind of unnecssary on a loader with 800 lb lift capacity.
2. the heavier the forks themselves the less your total lift cpacity will be.
3. the clamp ons seem pretty easy to put on/off
4. no welding of brackets needed to use
5. cost is a lot less than heavy duty forks which, as previously mentioned cannot be used to capacity anyway on a compact loader.
/ Bucket Forks
I think I'm convinced that the clamp-ons are the way to go, if for no other reason, the weight. Right now I'm having trouble even finding these kind. Two dealers, including my own are telling me that I don't want forks because with the extension out front of the 2710 they won't pick up much, and I will probably hurt myself. Nobody around carries them, or wants to sell them.
I'm aware that the capacity is reduced considerably, but mainly what I want to carry is brush and logs that aren't too heavy. Surely I can carry 200 - 400 pounds of that with my loader. Most of the time it won't even be anywhere near that much weight that I try to carry.
Anyway, I'm going to call my dealer back and have him call Gearmore again and get a price the clamp-ons.
I called CTI, who has a 1000# model, but they say the 2710 is too small for them.
Maybe I'll have to have them made.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2014 Ford Explorer SUV (A61569)
2014 Ford Explorer...
Kubota ZG222 (A60462)
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60352)
2014 Chevrolet...
