Brushog an weights
/ Brushog an weights #1
The Toolman
Gettin' ready to round me up some sorta 42" hog for my BX, an I knew I would need some weight up front.
I had a 1" by 4" by 78" piece of cold roll steel laying around that was left over from a welding/fab job I did 15 years ago. Finally found a use for it, in 6-13" pieces, 2-1/2"x8" bolts an nylok nuts an 90 pounds later, waalaa......
/ Brushog an weights #2
Good job. That ought to keep her from rearing up.
Yea, these dang 42" mowers are higher than a cats butt. But I don't want to go cheap and a 48 incher either. A 42" is a good size for the BX1800 IMO. I had a new ford boomer TC18 a few years back an a 48" cutter. It was all that little engine could do to pull the tractor an run the brush hog too. Thats why I think I'll go 42" this time, since the tractor width is already 42" also.
Bush hog SQ142 $1,635
Woods RCC42 $1,350
Land Pride RCR 1542 $1,300
Woods had the heaviest metal out of the 3
/ Brushog an weights #5
Nice work! Looks factory.
/ Brushog an weights #6
never thought about using plate steel to make weights. hmmmm.
3PT POST HOLE DIGGER (A63291)
3PT POST HOLE...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
John Deere 6125R (A60462)
John Deere 6125R...
