Brush Hogging Basics...
/ Brush Hogging Basics... #22
Richie...
A better primer would be for you to come over with your Fergie... I'll let the bees attack you... so I can get some work done... /w3tcompact/icons/laugh.gif
Before this Friday, call MacFadden's and get a price over the phone on some rotary cutters he sells... to keep his auction prices in prospective...
If he's got a Woods 8400 Brushbull for a great price... maybe we can put it in the back of your truck.../w3tcompact/icons/wink.gif
See ya...
Brush hogging about a month ago and going home (Twilight time-all the tractor lights are OFF)...
(I used my flash on the camera and it picked up the reflective material on the tractor...)
{see attachment}
/ Brush Hogging Basics... #25
<font color=blue>...wired up like a custom EarthForce machine...</font color=blue>
Harv... you really think Mark... needs more ideas for his EarthForce mover...? /w3tcompact/icons/grin.gif
/ Brush Hogging Basics... #26
Hey, John, cool picture.
Three questions:
1. Are you still using that 39 cent camera or have you gotten an new one? What kind?
2. What kind of cutter is that with two back wheels? I think I need that for my near-Oozama cutting. It would halve the down pressure on each wheel track.
3. Are you a III or a 3, for goodness sake?
/ Brush Hogging Basics... #27
Hi Glenn...
My youngest daughter is now the current owner of my "el cheapo" digital camera... after the bug bite me... I bought a Kodak on my way to the ultimate digital (whichever that may be.... I'm sure it will end up being an Olympus... with min. 10x optical zoom and must be fast for sports action shots {my girls' basketball}-like successor to the E-100RS...?)
The rotary cutter is a Brown 7' with dual tailwheels... I believe adds greatly to the deck strength/structure durability for cutting the heavy duty stuff...
Lastly... I think on my birth certificate it says 3rd... but that's a long time ago... when God was a kid.... /w3tcompact/icons/wink.gif
/ Brush Hogging Basics... #28
Thanks for bringing this thread back to life John.
I've picked up a few tips on how best I want to do our place. It's nowhere near as overgrown as your place but still I have some areas on the property that may be a bit challenging with the JD4710. Will share more in the future when the 4710 arrives and I get to put it to some practical use.
Bob
Re: Brush Hogging Basics... Online Video
A very nice rotary cutter video… ~~ about 5 minutes in length… Check out the sizing of the tractor to the appropriate cutter size used…
You should always size the width of the rotary cutter to the PTO hp & torque, the tractor can supply…
A rotary cutter is one implement you DON'T necessarily size to the width of your tractor…
Please choose the player version that you wish to watch and the speed at which you are connected to the internet. The Windows Media files will play as they download. The Real Player files must be downloaded first and then will play…
Windows Media Player Version
56k Modem - Rotary Cutter video…
100k Cable - 5 min. Rotary Cutter video…
Real Player Version
56K Modem - Rotary Cutter video…
100k Cable – Rotary Cutter video…
/ Brush Hogging Basics... #30
Curious how no Kubota's are in the video. I surely was happy to see the numerous Cub Cadets though. /forums/images/graemlins/grin.gif
/ Brush Hogging Basics... #31
Mr. Miller: Great video! It raises a question I guess I never really thought about. When you attach a 3pt cutter to the top link, is the attaching braket supposed to be pointing toward the ground?
I would start out with a ~ 30 degree pivot point…
Each setup should be customized to your routine/terrain… after you setup the toplink… run the 3-point lift through its up/down range slowly… and watch for interference…
(this applies to any 3-point implement... not just rotary cutters)
1) especially the PTO shaft coming into contact with the rotary cutter deck (while lifting and not paying attention… you will bend/destroy the PTO drive shaft in a hurry…)
2) cutter deck/tire clearance (deck cutting into rear tires, both lugs and sidewalls)
3) check chains/stabilizer arms for restrictions/binding (you DON'T want the cutter to swing/sway from side to side, when in the UP position… but you need some slight movement to prevent binding/stopping throughout the lift range)
4) Check for hoses/wiring/obstructions to prevent crushing/shearing…
5) Finally, adjust your range stops on your position control for repeatable settings…
While cutting, periodically check again… while crossing creeks, ditches, going up/down steep inclines for the proper clearances/motion of the implement…
/ Brush Hogging Basics... #33
Well, maybe you answered my question, but I don't understand. I'm referring to the position of the connector on the rottary cutter when attaching the top link. With the cutter in cutting position on the ground, what should be the position of the u shaped connector on the cutter? Should it be lose and pointing toward the ground, or do you screw in the top link and take the slack out of it so the u connector is pointing toward the tractor? And... since we are talking about it, how does one determine the best placement of the top link on the tractor itself? In other words, which set of holes should it go in. I think mine has three sets, maybe four.
/ Brush Hogging Basics... #34
Where you put the top link on the tractor side has to do with the draft control mostly. farther from the pivit point makes it more sensitive.
When I set up my rotary, I like to put it at the level I want to cut and have the top link just a little slack so the rear tire and tractor links are carrying the load. If you have too much slack whin you pick it up it will droop in back and possibly not give you enough clearance for the driveshaft. Having it with a little slack enables you to have the most ground clearance in back when backing into a bank or hill or lifting over something.
By putting the top link in the bottom hole on the tractor it will give a bit more lift to the back of the emplement. As my draft piviots from the top I use the top hole, I tend to think it is easier on the hyd system.
/ Brush Hogging Basics... #35
Totally off the subject, but how do you post the pictures so they automatically come up? I also noticed that when I saved them to my computer they are larger than the size allowed?
Murph
/ Brush Hogging Basics... #36
After typing in your text hit continue.
The "I want to preview my post and/or attach a file" should be checked.
Click browse and find the file you want and hit continue.
If the file is bigger than 100k then you'll need to reduce the file size some how. You can use PhotoShop, Image composer, etc..
<font color="blue">( how do you post the pictures so they automatically come up? ) </font>
Hi Murph,
I'm assuming you mean my inline pictures I posted in this thread?... (illegal to do now.../forums/images/graemlins/wink.gif)
This was before some regulations were enacted and a number of my pictures caused the thread to "widen" too much and s...........lllllllllll............ooooooooooooooooo.....wwwwwwww things down a tad... but here's an answer to your question...
inline use: (use [] instead of {})
{image}picture file name{/image}
You can only insert much smaller pictures inline so as not to cause any viewing difficulties similar to this...
/ Brush Hogging Basics... #38
Thanks John,
I appreciate that. But now to remember it. Experience and just doing it once will help.
Murph
/ Brush Hogging Basics... #39
Regarding in-post images:
The size limit used to be 150K, now it is 100K. Some of the old pics in the past postings would have been submitted under that restriction.
In-post images also significantly increase download times, which is primarily a concern for our bandwidth limited bretheren on dial-up-modems - and for Muhammad, who has to fit the bill for storage.
The only in-post images that can be displayed are ones you have written permission to use, or (as in JMIII's case), images that have been posted on TBN some time in the past.
Re: Brush Hogging Basics... Another Online Video
” To gain an appreciation of what our rotary cutters can do you have to see them in action. This video provides amazing footage of our rotary cutters knocking down brush that's up to 5 inches in diameter!”
Some ‘Serious’ Brush Hogging Video Demo /forums/images/graemlins/blush.gif
(about 6 min.-allow initial load time)
Windows Media 56k
Windows Media 256k
Real Player 56k
Real Player 256k
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2008 Ford F250XL, Crew Cab (A62679)
2008 Ford F250XL...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
SCAN TO RECEIVE TEXT UPDATES (A64276)
SCAN TO RECEIVE...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61573)
2010 Ari Hetra...
