Brush Hogging Basics...
/ Brush Hogging Basics... #42
Re: Brush Hogging Basics... Another Online Video
Looks like a beefy unit. My mesely 36HP isn't enough even for the 6 footer though, but I wonder how they are priced?
Don't hold me to it... about 2 years ago, the 6' unit was ~~ $3900 ? /forums/images/graemlins/smile.gif
/ Brush Hogging Basics... #44
Yowza. I guess that's worth all it is. Good thing my Cub ain't up to snuff, or I'd be tempted...
Re: Brush Hogging Basics... Tree Removal
You can use a chain saw on these small ~ 5” and cluster of saplings… but then you still have to dispose the debris…
By backing up, with the cutter in the highest position, use the weight of the cutter to bend/compress the tree and start cutting (slowly...), while also slowly backing the cutter into the tree (keep the tree with tractor pressure in the other direction)
(This 7' cutter without chains is ~~ 1400 lbs.)
Like one big grinder... One moment you see it... then you don't...
All gone... /forums/images/graemlins/smile.gif
(Why buy a chipper/shredder?)
/ Brush Hogging Basics... #48
John, that PTO shaft looks pretty close to the deck of the cutter when the deck is fully raised. Or is that just the angle of the picture?
BTW, that's how I handle bushes and other small yard debris. Back in, slowly lower, when the banging stops, you're done. /forums/images/graemlins/grin.gif
<font color="blue">...the angle of the picture...</font>
Hi Mike,
I forgot my clearance, but it's about 3 - 5" with the top link in my lowest position... If I move the top link higher, I can of course raise the cutter much higher and the clearance reduces but still is ok...
/ Brush Hogging Basics... #50
A farmer friend of mine calls that ' crayfishin' '. I plan to use it to clear out my multifloral rose. He said to be careful b/c he screwed up his PTO hydraulics. I think it was due to an incorrect PTO shaft length though.
- Gerald
/ Brush Hogging Basics... #51
Hey John, How big of trees can you back into like that? I have a wall of about 1-2" trees that when[not if, when. /forums/images/graemlins/laugh.gif one of these days] I get a tractor, I plan to cut them down that way. I am already planning to get a cutter on the small size for whatever tractor I get. [heavy brush, but small lot] Will that make a difference?
/ Brush Hogging Basics... #52
Thanks for the info JohnMiller3, I just got my first tractor and used your techniques today to brushhawg. I got a big rock with the loader, If it hadn't been for you I'd have found that rock with the cutter. My shear pin thanks you as well.
Well, I did a number of "tree" removal tonight...
One secret of success is don't get carried away, while "grinding" these things up with the brush hog... you must let the "slip clutch" assembly "cool down" after each tree.
On my present cutter, I have a 4-plate clutch assy... but tonight I was just about done and figured I would do this last little cluster of trees that have been in the middle of this one field for the past few years...
I cut 3" material all the time... so tonight I tried it again... but there were 9 - 3" trunks in a cluster... /forums/images/graemlins/shocked.gif
now I have a 3-plate slip clutch... the 4th one burned up in a puff of smoke... and that cluster of trees is now laughing at me... /forums/images/graemlins/wink.gif
(note the little black pieces of clutch material on the deck)
/ Brush Hogging Basics... #54
Could be worse John. It could have been a gear box, or about 50 shere bolts. /forums/images/graemlins/grin.gif
Re: Brush Hogging Basics... Befco Gearbox Cutaway
Befco Finish Mower Gearbox
Keep an eye on this mfr... excellent quality implements...
Re: Brush Hogging Basics... Woods Gearbox Cutaway
Woods 720 Gearbox
Re: Brush Hogging Basics... Woods 720 RC Cutaway
Woods 720 Rotary Cutter Cutaway
Woods Cutaway - Rear view
/ Brush Hogging Basics... #59
Great pictures! Now this is what we should see before making that equipment decision.. I wonder what they'd look like after 1000 hours of work?
TOTE OF HEAVYEQUIPMENT HOSES (A68842)
TOTE OF...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2013 WACKER NEUSON HF 690 FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2013 WACKER NEUSON...
2000 FORD F 350 S/A SERVICE TRUCK (A66091)
2000 FORD F 350...
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
