Brush Hog
/ Brush Hog #1
Dave Pic
JD 5203
Need to purchase a new 72 inch brush hog. Had an MX6, let someone borrow it, came back with a snapped cutter shaft, not worth fixing.
Running it on a 55HP, 46 pto HP tractor. At least a 2 inch cut. In RI where we grow mostly rocks. Suggestions?
/ Brush Hog #2
Woods Brush Bull! My three Woods rotary cutters have been the best I've ever owned or used.
Those shafts breaking on deere mowers is just plain common!
SR
/ Brush Hog
Thanks, I'll look into them. I've read that the Deere shafts snap, and until it happened. i didnt think much of it, however, looking at the shaft, it looks like the shaft was brittle the way it snapped.
/ Brush Hog #4
My buddy works for a bigger farm and theirs snapped a couple months ago, the idiots went out and bought another deere cutter! DOH!
SR
/ Brush Hog #6
Light duty and medium duty Rotary Cutters have a Class 3 driveline.
Heavy duty Rotary Cutters have a Class 4 driveline.
Somewhere in the manufacturers published specs this information will be provided.
Shop for a Rotary Cutter with a Class 4 driveline.
Could be Woods, could be Bush Hog brand, could be Brown, start by determining drive line capacity.
46 PTO horsepower is ample to power a 72" heavy duty Rotary Cutter which will have a Category 4 driveline. You could purchase one increment wider and still have sufficient motive power.
/ Brush Hog #7
SR
99% of brush mower damage comes from the operator cutting more than its capable of handling. Many break mowers then claim “I was only cutting grass”.
Let’s stop with imaginary the Deere brand bashing.….
If it’s an MX mower which isn’t designed for much more than thick grass or light brush, you will break it on heavy brush, rocks, etc. It’s their lightest duty cutter. :rolleyes:
The Deere CX are the toughest brush cutters you’ll ever use.
Neither of mine have broken even after striking boulders, logs, fence posts or concrete in 12 years of use.
/ Brush Hog #8
I have an Atlas MD685. It's ok and I think was $1900 when I got it, but the have gone up the past couple of years. I've only had minor issues like replacing the drive-in zerks. It didn't come with a manual or customer support. It is heavy and I like the 2 tail wheels.
/ Brush Hog #9
Bush hog 286. Over twenty five years old. Cut, plowed, chipped trees, beat stumps, cracked rocks and still going. Many sets of blades and bolts. Gearbox has never leaked and original driveline. Bought a newer used 286 to put into service when I sell this one. Newer model is built heavier.
Every manufacturer makes several models and duty levels.
/ Brush Hog #10
Imaginary? There's been plenty of deere cutters here right on this forum with broken shafts, all of them broke the same way. Do you really think they are all imaginary??
The place my buddy works at, he's no idiot and he said the mower has not been abused, in fact it broke when they put the Mc Cormick CX100's pto in gear, like all the others I've heard about, he says it looked like the shaft was over hardened.
deere has a problem, they should be fixing the MX6's for FREE. Just because you haven't had problems with yours, doesn't mean all the others are abusing theirs!
BTW, how many Woods Brush Bulls do you hear about with broken shafts?? Do you think only john deere mowers hit rocks, stumps and heavy brush??
SR
/ Brush Hog #11
I second the Brown Manufacturing recommendation as well. The 400 series are very tough, the 600 series are bombproof.
The Brown 416 would be comparable to the Woods Brushbull 720, just be careful because Woods also makes the BB72 which is a light duty piece of junk. Most manufacturers make light, medium, heavy duty like Woods, Landpride, Bush Hog, Rhino etc.
You don’t have to worry about this with Brown, they ONLY make tough high quality equipment.
Be aware that “heavy” duty to one manufacturer doesn’t compare to heavy duty to another, so check the weights, steel thickness, gear boxes, and reviews.
There was a long time there when Woods had notorious issues with paint peeling for instance, but it was purely cosmetic, unlike the well documented issues of the Deere cutters.
This is an old invalid point at this time, but I also liked that although Brown now uses foreign made gearboxes, they were at least the last manufacturer to hold onto using gear boxes made in America. My 472 has an American made gearbox.
I have the predecessor to the 416, the 472, about 22 years old now.
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
Bush Hog 3008 (A64127)
2016 Ford Explorer (A59231)
2016 Ford Explorer...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
